Question about RCA P46921 46" Rear Projection Television
RCA Projection TV model #p61926
Pictuure is not focused, tv screen curves the picture with half upside moon at the bottom and half moon at the top. Each indvidual in the picture has shadows (you can see the layout of the picture behind each figure in the tv) and each text on the tv gets curved so is the tv menu and this is happening on all the connections. Please help Picture sags inward at top and bottom and both sides
  • clfitz Sep 29, 2008
    Same as described, curves up at bottom and down at top, with "shadows" of each individual color behind the picture elements.
    Now that I know what the problem is, how do I fix it, just replace the convergence board? Where do you get those?
  • ELIZBLR Apr 17, 2009
    THE PICTURE IS SAGING AT THE TOP LEFT HAND CORNER. ALMOST LIKE A DOUBLE PICTURE. THERE IS ALSO A LINE THROUGH THE MIDDLE OF THE SCREEN
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Posted on Feb 11, 2008
Green half moon at bottom of screen, then no picture or sound
likely a convergence problem which has gotten worse
May 14, 2012 | Hitachi Televison & Video
Our television just began having what looks like a 'double screen'...or the picture has a 'shadow'...and also looks as though the entire screen 'curves' ..at the top and bottom of the screen it is...
Hi
Thanks for using FixYa. First of all please check whether all the cables from your dish network are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage the tube. So you need to do only a small adjustment. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board or a problem in the RGB coming from the video jungle IC. The price to resolve the issue will most likely run you about 300 to 500 bucks, unless it is the picture tube.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Sony Televison & Video
Curved picture at top and bottom
if it is bowing from top and bottom your looking at a convergance problem if you keep using your tv soon there will be no picture at all when the board crashes... convergance board needs to be replaced... hope this helps..
Apr 11, 2009 | Samsung HCN4727W 47" Rear Projection...
Sony kp53hs30 screen is curved at top/bottom when in widescreen
on the sony we have to make the convergence alignments on all the modes, only a qualify tech can do that
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Magic focus grid not straight.
i'm no expert by any means; but I wonder if it could be as simple as the reflective screening on the inside comming loose. I have a 65" and I took it apart to clean it. The reflective screening looked to me like it could be a weak point. Just a thought.
Jul 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA P46921 46" Rear Projection Television Logo
387 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
