Question about Microsoft Xbox 360 Console
Xbox 3600 i pried the door open now it wont close
  • kolty Feb 11, 2008
    thanks , yea but i opened the case
  • Hillary411 Apr 05, 2008
    XBOX 360, can't close door at all, not under warranty, and do not want to be without it for any length of time.
Theres
Posted on Mar 29, 2008
  • 178 Answers
It sound like the cd dtray is off the track? Is this still under warrenty>?
Posted on Feb 11, 2008
My xbox 360 tray will NOT open or close. I need to pry it open and push it closed. And when closed it still will not "read" the game. How can I fix it? i only got it for Christmas...would it...
Yes! you should have a standard 1 year warranty, what ever you do don't pry the tray open, it will cause more damage and void warranty, It should be returned to the place of purchase for repair or exchange.
Jun 05, 2011 | Video Game Consoles & Games
My two yr old got to my xbox now the door wont close,it just clicks
the tray is off the track cant fix unless you open xbox but that will void the warrenty other than that you have to send into xbox
Oct 27, 2010 | Microsoft Xbox 360 Console
Tray wont open
Power your unit off using the button. when it's off unplug the power source from the back of the XBOX and leave it out for 30 sec. Reconnect the power source and reboot your machine. Try the disc tray again. If it doesn't work try giving it a tap or a solid knock on the top of the case above the disc tray while it's trying to open. Don't drop the machine or try to pry the tray open. If it doesn't open when you tap it then try light pressure on the front of the tray while it's trying to open. (you can tell it's trying to open because the disc status on the screen will say opening...)
Now if the above did not work
Get a straightened paper clip.
Remove the faceplate carefully starting from the indention that you will see on the side
After removing the faceplate, look for a pinhole just below the disc tray.
*There are two pinholes just below the cover of the disc tray and one pinhole below the X and B of XBOX logo.
*You can try any of the three holes
*Pinholes are so small that the girth of the paper clip is the only object that can fit through the pinhole.
Now insert the paper clip into the pinhole then put a little pressure until the disc opens.
If it opens try to close it, if it closes try opening it again, if it wont open the second time then it need to be serviced
If it opens try to close it, if it wont close try nudging the disc to the right and then to the left, if nudging doesnt then it need service
If it wont open after trying all three pinholes - its needs service
It may be jammed or the drive gear stripped.
CALL XBOX CUSTOMER SUPPORT 1-800-FORMYXBOX
If that doesn't work . call Microsoft and they will instruct you on warranty work.
Nov 24, 2009 | Microsoft Xbox 360 Console
I turn the xbox on & the tray won't open. I can pry it open & when I put in a disc & try to close, it closes half way, then opens all the way again. If I try to close it & then force it...
the motor that opens and closes the tray may have malfunctioned, if you still have the xbox receipt you may be able to send it in and get it replaced/fixed.
Jul 09, 2009 | Microsoft Xbox 360 Console
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
Chevy Blazer door wont close....
Not sore if you have the answer or not. Here it is. MANUALLY place interior door lock latch in the UNLOCK position. Now LIFT UP outside door handle as if opening. While holding it up with your finger ( no prying ) lift up closed latch. Now you should be able to close your door normally.
Apr 01, 2009 | 2002 Ford Escape
easy fix open the door take a screw drive and slighty pry the latch on the door back while pulling up on the door handle magic you can lock ya truck now.
Jan 09, 2009 | 1989 Chevrolet C1500
Hi...
I use a place called
www.studiosoundelectronics.com
or
matelectronics.com
Studiosound will even tell you how to measure your belt if you need to
Godspeed,
Scott
Dec 16, 2008 | Yamaha CDC-845 5-Disc CD Changer
Quad cab rear door closed and wont open
what you have to do is make sure door lock is in unlocked position put a flash light inside the door to see you need to get a screwdriver into the release spring area try to pry up on the hook area that flips over the piece thats mounted to the door jam it should release sounds like you need to spray wd or blaster in the lock assembly return spring not kicking back
Sep 11, 2008 | 1998 Dodge Ram 1500 4WD
Xbox disc door not shutting properly.
BOUGHT AN XBOX 360. DOOR/XBOX NEEDED TO BE REFURBISHED.
Jul 09, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
