I have my Philips DVDR3450H with the HD broken. I bought the same (brand, model and size) HD but it is not recognized from the DVDR3450H. I would like to prepare it with a PC. Which format setting should I use?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
