D52w17b 52 the sceeen just when blank no picture
  • 5 more comments
  • welchco Feb 12, 2008
    THE LED LIGHT COMES ON BUT IT'S NOT BLINKING. AND YES I HEAR A CLICK WHEN YOU TUR ON THE TV
    I DON'T SEE A RED LIGHT. THE POWER LIGHT IS GREEN AND IT IS IN ON BUT NO BLINKING
  • welchco Feb 13, 2008
    hi, where is the red light? you said check the horizantal section.what is that? i don't mean to sound dum.
    thanks for geting back so quick. the horizonal section is the board in the front of the tv behind the three projection tubes? i'm at work now but when i get home i will check them. and let you know what i find
  • welchco Feb 18, 2008
    hi, sorry it's taking me so long to get back to you. i checked the horizontal sweep board.one of the capactors had about 170.4 ohms & the other one had about 19.5 ohms. the capacitors don't have any part #s and seem to be soilder on the board. no part #s on the board. thanks
  • welchco Feb 22, 2008
    HI,
    I ONLY HEAR ONE CLICK WHEN YOU TURN THE SET ON. DO YOU KNOW WERE THE RELAY IS ? THANKS
    I WILL CHECK WHEN I GET HOME THANKS
    Guru:
  • 1,894 Answers
The relay controling the main picture supply should be faulty and that is why you are hearing the clicking sound....better get it changed..
Posted on Feb 22, 2008
  • 1 more comment
  • dewan nafees ahmed Feb 22, 2008
    there will be relay that controls the power supply to the main display device...
    if the relay is faulty in power supply will not be passing through the areas which it is necessary to pass
  • dewan nafees ahmed Feb 26, 2008
    ""Relay will only be in "broadcasting" of AM and FM signals.""
    any rule??
    relay is a protection device. and this is the one which is responsible for tripping of the circuit when there is some short circutiing in the board.
    this type of protection can be found in power boards of many devices.
    am i wrong?
    relay is a basic component used in all circuits for protection of power circuits. if the relay is not maiking that "tick" sound then what component you suppose will make that sound?? capacitors??
    i dont think so...
    anyways good luck.
    thank you.
    dont forget to rate the solutions.
  • 4,889 Answers
Ok can u tell me if the LED(power indicator) infront of the tv is blinking or not?If not do you hear a click when you push the power button? Please provide us with this information so that we can offer further assistance.
Posted on Feb 12, 2008
  • 5 more comments
  • eagle338
    eagle338 Feb 13, 2008
    hi there, red light flashing means a shorted parts on the unit. You will need to check the horizantal section for any shorted it. If you find anything faulty note the part number or name any information you can provide about the faulty part and i will tell you how and where you can get it.
  • eagle338
    probably some faulty capacitors
  • eagle338
    Sorry for being vague... what i meant was you have to turn off the power supply and open the set. Using a multimeter look for faulty capacitors in the horizontal sweep section or any other open circuits. Please note that this is a rather difficult task if you are not familiar with electronic circuits and if this is the case i would leave this job to a tech!
  • eagle338
    Yes that is the horizontal sweep and sure thing you can let me know so that we can proceed further..
  • eagle338
    eagle338 Feb 22, 2008
    It is a problem in the power supply section.. From The readings you have provided The problem has got to be in the power supply section. You will have to replace one or more faulty capacitors which are causing that click sound.. I would advice you take the help of a tech to get them replaced. Repairs would run you about 75$.
  • eagle338
    Dear sweet rascal what do you mean by "relay" and "picture supply"!!!!!!!!!?
  • eagle338
    Sure thing welchco. Hello sweet rascal there will be no component called relay in televison. Relay will only be in "broadcasting" of AM and FM signals.
  • 796 Answers
Hello sir
  • isaac johny
    isaac johny Feb 12, 2008
    see for the patten of red light blinks...
    see properly in which pattern it is blinking
42LG5010 LG Flat Sceeen TV Picture fault. Left side multiple images and jittering. Intermittent fault.
If it is not a bad solder connection that comes and goes as you flex the set or tap it with your hand, then it is likely the capacitors on the PSU Board that need replacing.
Nov 06, 2011 | Televison & Video
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
RCA 52inch DLP TV - D52W17B Lights up, but the...
Your model uses CRTs instead of a bulb. Its usually the deflection board which causes that. Thats about 180.00 for a replacement board.
May 20, 2010 | Televison & Video
Gas dryer flame keeps going out, clean lint sceeen...
normally it is a flaim sensior or moor often the gas coils www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
I replaced lamp and picture shows well except at
Light from the lamp is getting itnto the top inside of the set Just changing the lamp should not cause this problem. I've seen this where someone has cahnged the light engine and did not reinstall the foam gasket aroun the lense . But any way look for an opening from the lamp area into the upper chamber where the mirror is.Light from the lamp should only go into the light engine and not into the upper chaber except through the projection lense.
Nov 27, 2009 | Toshiba 52HM95 52" HDTV Projection...
Screen is blank - at power on sceeens flash screen
there is no signal coming in from graphics card. please check graphics card.
Nov 01, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Toshiba 52HL167 52" HD LCD
I have similar problem. Sometimes it will show only a blank screen. Just unplug the AC cord, wait a few seconds and plug the AC cord back in. This will reset the processor and the picture is back. It happens once a month. Not a big issue to call warranty service.
Jun 21, 2008 | Toshiba 52HL167 52 in. LCD HDTV
RCA 52" projection
When you are changing channels and the screen normally blanks to black between channels, do you instead see a reddish screen?
Did you check your event codes?
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
