Their is no filter on the heater, your pool filter. If it is dirty your flow rate will go down and without enough flow the heater would overheat, but for a pressure switch in your heater. So if you clean your baskets, (pump and skimmer) and clean your filter this may help. Without more info this is all I can tell you.Hope this helps.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
