Question about RCA P61927 61" Rear Projection Television
Tv will not receive any signal from remote
Replaced with new batteries. tv is set on chennal 3 and now i cannot change to s-video, video-1 or video -2
  • Naren47 Feb 12, 2008
    All-though the remote does not work the problem is solved as i use the cable box remote to surf the channels. now I can play the nintando Wii, dvd and other aux source.
    Thanks for your problem solving suggestion
    Naren.
You should be able to scroll down on the tv 's channel buttons to get to the s-video, video 1 ect. inputs. there may also be a video/aux/source button on the tv you can press.
wg
Posted on Feb 11, 2008
TV will not change or show channels
You don't say whether you have had it working at that location before. When you move a TV between houses, it is necessary to retune your channels. Would recommend returning to first time installation.
If you haven't moved it recently there are other reasons why this might happen. 1) There is damage to your aerial caused by weather, 2) A power surge or loss of power to the memory battery on your video board has wiped the frequency information from the memory [the memory battery is like a watch battery that keeps a small amount of power going through the system to it can keep your settings when unplugged], 3) The internal tuner board for your TV has packed in.
If '1' is the case, obviously you need your aerial fixed; if '2' is the case you need to retune again [you'll know if the battery is dead if you have to retune every time you turn on the TV]; if '3' is the case you either need a replacement AV board or someone to solder a replacement tuner board to it.
Jun 17, 2013 | Philips Phillips 40 in. LCD HDTV
When I go to INPUT the sereen says: VIDEO LOCKED
Hell My Sansui Hard rock 21 eye tv has been chennal & voliume locked.
or remot not working tv screen small
Aug 25, 2011 | Sansui D 27" TV275 TV
I changed my tv and in new tv whenever i try to
You need to try and change you video audio settings for that tv,on your ps3.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Tv continually changes from video 1 to video 2 to video 3 etc... sometimes get black screen as well + menu items. Based on a suggestion, I removed the batteries from the remote but that does not help. This...
It sounds like a switch problem inside the TV if you have already tried removing the remote batts. Try replacing the switches behind the push buttons on the front of the TV. Also, if glass cleaner or some other foreign substance has run down the front of the screen and into the set, this can cause switches to short out and cause this problem. The part number for the switches is 23145227. Thanks for using fixya.
Jan 20, 2010 | Toshiba 32AF43 32" TV
Tried to connect original xbox to video 1 but no
Replacement of remote control battery solved problems.
Jan 06, 2010 | RCA 27V530T 27" TV
How do i set up the channels in order bbc 1 bbc2 etc to match the buttons on the remote 1 2 3 ect its a LG 42 INCH TV
selact menu on remot cantrol and see on the screen tunig menu in chenal edit to selact .
frist selact ch for edit and set your chennal no 1 /2 or 3......after the selact no prees OK key to fix your fureat ch. in your selacting no.
EXP:
ch . pisesion 36 [BBC1]
edit ch No 1
then prees OK key and see your BBC! is ch no 1 on your remot.
Oct 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Kv 27ts27 set works fine except lost color. now black and white
pls check and selact in your tv colour system PAL / NTSC / AUTO
set Auto colour system is Best .
set chennal Auto serch
if not
then problum is in side tv pcb. so repare pcb with nr. thech.
Oct 30, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Toshiba 35a44
I contacted Toshiba and they said to turn unplug the TV for at least a minute, if that didn't reset it, then they gave me a service to contact. So I unplugged the TV when I was going to be gone all day, and tried it when I got home, no change at all. I had a repairman come by and he said the problem were the buttons on the TV that had to be replaced. He quoted me $240/labor and $5 for each button to replace (7), considering I only paid about $500 for the TV in December of 2004, I decided to just get a new tv with a warranty. I ended up getting the LG LCD Tv.
Jul 23, 2008 | Toshiba 35A44 35" TV
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
What do I do for tv switching from tv to various video modes and cycling through set up screens
the tactile switches on the control panel cause this problem . they could'be stuck or have some kind of contamination like liquid. or just bad . cost to repair aroud 60.00 dls if this helps please let me know
Jun 12, 2007 | Toshiba 35A44 35" TV
RCA P61927 61" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
