Question about Honeywell Programmable Thermostat Heater
Wiring a Honeywell Deluxe Programmable Thermonstat
I have a Braemar Ducted Gas Heating System, Model no. TB65N with a Honeywell Deluxe Programmable Thermostat control panel. There are two wires that come out the wall, one is just red and the other is red down one side and black the other side.
Which wire connects to which letter on the control panel?
From left to right the letters are R, RC, H or W (letter is a bit smugged), Y, G.
Could you possible help me out? Thanks.
  • 148 Answers
Did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Posted on Mar 08, 2008
Honeywell smart thermostat. model th9320wf5003ww
Assuming the only change to your heating system is the t-stat and it was installed by you, there are a couple things you may want to check: Double check the wiring to be sure all wires are secure and that they are in the correct terminal. Always go by what the wire controls. I never assume the colors are correct.
Verify that the programmed settings are correct, especially the type of heating/cooling system and the stages.
Jan 03, 2018 | Honeywell Programmable Thermostat Heater
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Unable to get Braemar Spectrolink thermostate to switch to auto
I have exactly the same problem, did you ever get an answer to this issue?
Sep 08, 2009 | Honeywell Programmable Thermostat Heater
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Oct 16, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
383 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
