Question about Car Audio & Video
Setting the timing without the specail tool to hold the cams on 3.5 chrysler concord 1996
I having a problem setting the timing on this 3.5 chrs. concord. I don' have the specail tool. An none of the parts store around here carries the tool.Please help me, I've been involve going on a month.
  • 82 Answers
Why do you need a special tool???
all you need to do is take the spark plug out of the #1 cylinder stick yuour finger down in it and let some body turn it over barely bumping it until the cylinder touches the top make sure its at the top it may bump your finger a few times until you know ere the top truly is then match the marks on your timing chain or pullies
Posted on Feb 11, 2008
How to set timing on 1994 chrysler labaron 3.0
the valve springs are pushing against the cam lobes and turning the cam, you have to hold them with special tools or wrenches, usually the will stay in time if you hold them lined up with the marks and release gently on wrench, don't breath or they will jump
Aug 25, 2014 | 1994 Chrysler LeBaron
The oil cap turns and clicks, how does it come off without just leaving the seal underneath? 1996 concorde, chrysler car
Try pushing down the cap while turning it just like a prescription bottle if it comes off and the seal is still onside you need to replace the cap it is broken
Sep 14, 2011 | 1996 Chrysler Concorde
96 Chrysler Concorde ran out of gas put gas in now it wont start
If you ran out of gas you may need to bleed the injectors for air in the line. You can find the bleeder valve on the fuel Rail. It looks like a tire valve stem. Have someone start or ttry to start the motor over while you hold it down to see if any air is comeing out. Continue to hold untill all the air is out and nothing but fuel is flowing. By this time the engine should be running.
Mar 09, 2011 | 1996 Chrysler Concorde
In removing harmonic balance on 1996 chrysler concorde 3.3 engine, my chilton repair book states to use a 4" 3 arm puller and a special tool to place in the center of the pulley, I'm have a problem...
Hello, This is also called a gear puller. The best place to find them is at a tool store like sears, harbor fright Farm & Fleet or Fleet farm. I know harbor fright has them causes that's where I got mine. Harbor fright also has a web site online. If you have any more questions feel free to ask me. Good luck
Feb 19, 2011 | 1996 Chrysler Concorde
1997 chrysler lhs turns over but no spark. already changed Cam pos. Sensor and Coil block
Try the crank sensor this is the sensor most likely to cause this not the cam sensor. To get to the crank sensor you will have to jack up the passager side of the car and the sensor is located on the transmission bell housing about 3/4 of the way up on the trans were it connects to the engine.(all on the passager side of the trans) It has a 3 wire plug and one 10mm bolt that holds it in. Hope this helps
Mar 06, 2010 | 1996 Chrysler Concorde
Timing belt
you will need to rull the timing cover off if belt has not spun or broke remove belt and install new one if belt has spun or broke you will need to line up timing marks on cams and crank and install belt
Oct 04, 2008 | 1996 Chrysler Concorde
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
