Installing MSN Flight Sim Deluxe Edition.
My DVD player doesn't reconize the DVD. I am running VISTA but the program said it was Vista compatable.
I have checked the DVD drivers and rhey are working correctly.
Thank you
Ben
    Genius:
  • 1,019 Answers
go to My Computer/ open the drive D:- E:- Manually.
look towards the bottom of the files, and locate. installshield wizard, or setup.exe.
Run the program from here to install.
Mike @ Compurepair.
Posted on Feb 24, 2008
Can not get Adobe PhotoDeluxe2.0 to install on windows 7. Worked fine on Vista
Adobe Photo Deluxe is an older program that does not seem to be compatible with Windows 7. you should contact Adobe to see if they have an updated version.
However, you can try the following to see if it will help.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1)Right click on the Program
2)Click on Properties
3)Click on Compatibility tab
4)Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 04, 2013 | Microsoft Windows Vista Ultimate Edition
Is there a version of Bible Library Edition compatible with windows 7
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Bible Library Deluxe Special Edition 5.1, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Nov 25, 2010 | ValuSoft The Bible Library Deluxe Special...
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
http://www.novadevelopment.com/Support/Updates.aspx
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Jun 30, 2010 | Nova Development Photo Explosion Deluxe...
IBM Via vioce Pro dosn't work on my vista run computer..
After installing the program, right click on the icon and select properties, hit the compatibility tab and run the program in windows xp compatibility. You can also visit the website and see if the program is supported in Vista. There may be an update to make it work.
Good Luck,
NOLA Tech
Feb 05, 2010 | Microsoft Windows Vista Ultimate Edition
Cant get pc to run it says dont rconize help!!
If you have new pc's you probably have a windows vista operating system. Check and make sure your program is compatable with the windows system that you have. That may be the problem since certain programs not set up for vista will not download or run in vista.
Dec 04, 2009 | Broderbund The Print Shop 22 Deluxe Full...
Installing Adobe Photo Deluxe 2.0 on Visat
You may need new software, you might want to look for it on the web. Is your Vista 32 bit or 64 bit version? If 32 bit, you might be able to run it in compatibility mode.
Oct 03, 2009 | Microsoft Windows Vista Ultimate Edition
I cannot load my disk Setup on my computer with Window Vista syst
Win95 was a 16bit programme so unless you load Win95 nothing will work properly.
Jun 10, 2017 | Microsoft SideWinder 3D Pro Joystick
Msn did not work because of lcid 1033
if you have the MSN toolbar try un-installing it from the control panel. if that doesn't work try right clicking on the LIVE messenger shortcut go to properties, go to compatibility tab and choose "run this program in compatibility mode for: windows xp sp2" if that doesn't work as-well. un-install the entire thing and reinstall it.
Feb 20, 2009 | Microsoft Windows Vista Ultimate Edition
I can not run flight simulator becoz,d3drm.dll has not been found
U can go to google.com And Search for   '' d3drm.dll download it .....
Jan 16, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
88 people viewed this question
Alun Cox
David Payne
David Payne
