Question about Video Cameras
JVC help I can not get my maxed out hard drive to transfer to my I MAC OSX TIGER so I can burn it to a dvd and clear my camcorders hard drive!!?? Worse, I can't find any of my paperwork or manual. I bought it from Best But 1 1/2 years ago! Can't I down load the software off line? Please help! Only still pictures will come up under I PHOTO JVC GZ-MG115U Everio 32X optical zoom 30GB
    Scholar:
  • 84 Answers
If you have a dvd recorder, you can hook up the line out of the camcorder to the line in of the dvd recorder and put it on dvd that way.you then must finalize the disc. once you do, then you can burn copies on your computer.
hope this helps
wg
Posted on Feb 11, 2008
I have an apple laptop, how do I transfer from my camcorder to a dvd on my apple.
You do not need drivers to get the footage from tape to a Mac. You do require a firewire cable and use iMovie or Final Cut to capture.
Oct 04, 2016 | JVC Everio GZ-MG21 Camcorder
Tip
Make osx dvd image in mac
Making a DVD Image...............
Step 1. Insert the retail Mac OS X Install DVD into your drive.
Step 2. Launch Disk Utility (Applications > Utilities).
Step 3. In Disk Utility, you will notice a white pane on the left hand side. In the pane, select the Mac OS X Install DVD by clicking on it once.
Step 4. Click New Image on the Disk Utility toolbar.
Step 5. A dialog box will appear. Give the new image a name. I used 'Mac OS X Install DVD'. Select the destination where you wish to save it. LeaveImage Format at Compressed (default) and Encryption at None (default).
Step 6. Click Save to begin creating the image.
Step 7. Once your image has been created DO NOT mount it. Leave the image alone and proceed to the next section.
Burning the Image...................
Step 1. Launch Disk Utility (Applications > Utilities).
Step 2. Click Burn on the Disk Utility toolbar (upper left).
Step 3. Navigate to where you saved the DVD image created in the previous section. Click on the image file, then click the Burn button. Do not drag and drop the image file into Disk Utility during this step.
Step5. Insert a DVD when prompted and proceed to Burn it. (use good quality media)
Using these exact steps I was successfully able to create a personal backup copy of Mac OS X Tiger. I hope this tutorial helps. Enjoy the newfound features in Tiger!
on Feb 05, 2010 | Computers & Internet
Operating System Requirements
No Problem
Always do a full backup before updating your Mac OSX. Use Carbon Copy Cloner to make a bootable "Clone" of your current Hard Disk. Once the clone is done... Boot from the clone. (Hold Option Key down at Startup and choose external HardDrive with new clone OSX)
Verify that this clone Boots & has all of your current data.
Use the "Mac Tracker" App on the Mac or iPhone to see what the maximum OSX system your model can handle. (Makes no sense in installing just OSX10.5 if you can go to say OSX10.7
Download a copy of the MacOSX 10.5.8 installer DVD (Saved as a .DMG file here Fenopy.se (Search for OSX 10.5). OR OSX10.9 (free download) if your Mac can run on this latest OSX.
Burn your OSX Install software to DVD. Use Disk Utility with your .DMG (Disk Image) File and select the .dmg from the LH Side menu to burn to DVD.
Once burned, try booting from the DVD. If that works OK then you are ready to go. BUT not quite yet.
You really don't want to install a new clean system over top of your existing system. This would be like a Band Aid Fix.
(This is where you must have your current existing system cloned to an external hard drive. Just like i mentioned above.)
Because, now you will start up or "boot" your computer from the DVD installer disk you just made. You will find the Disk Utility tool in the top menu. Use this to FORMAT your internal Hard Drive. (Dont Have your External Drives connected at this time... for safety.)
Choose ERASE or Partition and Select "Mac OS Extended (Journaled)" as the format type.
This process only takes a few minutes. If you have more time you can select the Security Option (choose fastest or single pass) then hit erase button. The security option in this case is only used to write "ones" to every sector on the disk thereby thoroughly testing the drive. This happens to be the ideal time to make sure you have a good flawless internal hard drive. Peace of Mind for older Macs.
Once completed, your drive is totally empty, you have lost everything unless you have made a "clone" beforehand.
Now you can run the installer and leave that process to complete for half an hour or so.
When installer has finished the Mac should reboot itself (you will hear install Jingle), with the new clean OSX installed. You can then manually answer all the questions if you want and give it your Network passwords etc. OR You can select Migration Assistant and migrate all your previous files & settings automatically from that external drive "clone" you made earlier.
You should now have almost a brand new clean Mac to install your new scanner software on.
Also... if you only installed say OSX10.5.0 then you will have updates to download on line, then install, to bring your Mac up to 10.5.8
I run this process on my Mac's at least once a year so that I always have a clean OSX with defragged hard drive so I can work reliably for the next few months. If not... I still have my "Clone" to boot from.
By the way Apple's latest systems since 10.7 (I Think) have an emergency boot partition automatically installed by the installer software. You just re boot & hold the OPTION KEY down and you are given the choice of booting from this bare minimum emergency system. It is heavily limited as to it's functionality but Disk Utility is there to look for problems.)
Good Luck
Feb 21, 2014 | Apple Mac OS X v10.5 Leopard
Want to use .mod to create movies on Apple Mac's iDVD /iMovi
Hi!
Yepp! you need a program like DVD Creatot for Mac or any aquivalent program.
Here is a litlle hint how to play MOD files on Mac:
http://www.moviesmac.com/tutorial/mod-format-to-dvd-mac.html#part2
Good luck to you
Please take a minute and rate me
Nic
Feb 04, 2009 | JVC Everio GZ-MG21 Camcorder
What do I need to transfer video from jvc cam to my laptop
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
You can then use Move Maker to any disc burning software like Nero to create the movie disks.
Jan 04, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
JVC Camera without software to burn to dvd
i have vista and this worked for me
make sure cam is off and usb it to ur pc.
turn on cam and chose back up to pc
go to computer and open the foloders on your cam
minimize the page and drag the sd folder to your desktop
transfer files to windows movie maker
edit publish to whatever you want(dvd)
if you have vista you dont need the camera software,in fact the software sucks neway
Dec 25, 2008 | JVC Everio GZ-MG21 Camcorder
GZ-MG330 with mac OSX 10.4.10
I had the same problem with the Everio MG330 and I have fixed this problem!!
iMovie needs to be updated to v7.1.1 or it will NOT import from the Everio MG330 HDD video camera.  iMovie '08 is not enough, it needs to be upgraded to v7.1.1
I searched long and hard and finally found this.  IT WORKS NOW!!
1. Update to iMovie 7.1.1 2. Close iMovie 3. Plug in camera using USB cable (iMovie is OFF) 4. Open camera viewer to turn on camera 5. Choose top option (I think it is watch on PC or download to PC or something like that) 6. Open iMovie and follow the pop up instructions for importing.
Please go back to all of the other places you have looked to fix this problem and post this.  Let's help each other.
Nov 09, 2008 | JVC Everio GZ-MG130 Camcorder
Transferring hi8 tape to Everio hard drive
I play the hi8 video back to the T V lcd 32 screen
Because you video in not in digtal format
From the Telly i set up the try pot install the camcorder jvc 30
everio zoom in to size start the camera camcorder
for video start the hi8 video in the telly pres the recorder
on camcorder and record. This is the way the piratcy is done in the Cinamas
corra
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
HOW TO BURN MOVIE ONTO DVD WITH MY COMPUTER
i suggest you obtain the program cyberlink powerproducer onto your pc which is such a user friendly program to help you burn video from camcorder straight onto a dvd. you should be able to download from the internet.
May 12, 2007 | JVC Everio 25x/20GB Hard Disk Drive...
Video Cameras Logo
165 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
