Question about TruTech PLV16320 Television
Truetech tv/dvd player
It has a connection to act as a computer monitor but it gives me a "not support" message. HELP!!!
    President:
  • 814 Answers
You can contact TruTech technical service at these telephone numbers : 1-800-252-6123 and 1-888-252-6252. They should be able to help you with your problem. I hope this helps you with your problem.
Posted on May 17, 2009
Can I use samsung syncmaster B1930 monitor as a tv
It won't directly connect to a DVD player because it is NOT a TV. Monitor and TV sync and refresh rates are not the same.
Dec 13, 2014 | Samsung Computers & Internet
Can i connect my monitor cable to a DVD player?
depends on the dvd player.some come with the monitor view option.If not u can use a tv card on your computer and connect the dvd through it.hope i've been o help.cheers
Mar 18, 2012 | Dell Computers & Internet
How can i use my acer monitor as a tv i lost my manual
The manual won't help you to much in this regard.
This monitor is a standard type that has both a VGA and DVI input.
Normally what you would use with a personal computer.
If you want to use it as a TV monitor you will have some sort of device that outputs to VGA or DVI.
DVI stands for "Digital Visual Interface" and it's preferable over VGA as it should potentially give you a better image.
This means:
A) A computer. You can build your own media TV and watch internet streamed shows like Hulu, Netfix, use as a DVD player, etc. I recommend this route. No more dependance on Cable companies! You just need internet.
B) Find a DVD, and, or Tuner/Cable/Satellite box that has these outputs.
If you want to use Cable or Satellite, contact your provider company and see if they have a box that will output to either VGA or DVI. Might have a hard time finding one of these, or it might cost more then it's worth.
C) Buy a S-Video input to VGA/DVI output. You can buy these for around $40.
Then you should be able to hook it up to just about any device as most modern TV devices will have an S-Video outputs.
Feb 17, 2011 | Acer AL2032WD 20" Flat Panel LCD Monitor
Integrating MAC with Philips TV & DVD Player to BOSE Companion 5
The best option here is to use your TV as a secondary monitor for your iMac. Doing so would require the correct type of connector in your case a mini-DVI to HDMI connector.
Once it is connected, you have three options - you can have it mirror what's going on on your iMac's display, have it act as extra monitor 'real estate' - that is to say extra space that you can drag windows onto and so on - or you can have the TV act as your primary monitor.
All of these options can be changed when your TV is connected through Apple menu > System Preferences > Display > Arrangement.
You don't really need to worry about the DVD player on the TV as the Mac OS has a DVD player application built into it. You can use it or the TV's DVD player, it's really up to you.
As for connecting both of them to the same speaker system, you should be able to purchase a connector that will go from the audio out port of your TV to the audio in on the back of your iMac. You would then be able to select the TV's output in Apple menu > system preferences > sound > input.
Jun 06, 2010 | Apple iMac 24" Desktop
Connecting DVD player to ASUS vw192t monitor, get 'out of range'
are you using an adapter with amplifier built in?...or just cables. You cannot just connect hdmi to video in
Nov 11, 2017 | ASUS VW192T Monitor
Plasma Television Connection
hmm a bit...complicated but if they all use HDMI then one cord is all you need going to the tv from the bose sound system while any other HDMI connection should directly go into the bose sound system or if the dvd player uses RCA then RCA sound should go to the sound system and video directly to the tv
Apr 22, 2017 | DFI LANParty UT RDX200 CF-DR Motherboard
PC flat screen monitor to DVD player hook-up
It appears that the monitor was designed to work with the display circuits and software driver on a Personal Computer. There is no circuitry in the display to handle the out put of DVD player. A smart TV has the circuitry. the display does not.
Nov 26, 2017 | Princeton Digital VL1916 19" LCD Monitor
Polaroid TLA-01511C
Tried to use my TV as a computer monitor. When tries to boot up, will go to "No Signal". All hooked up correct. Is ther something I need to do tobe able to use the monitor with my computer. I have a Dell Desk Top Computer.
Jun 16, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Trouble connecting DVD
NEWER TV SETS REQUIRE THE RIGHT CABLES, USE S-VIDEO OR AN HDMI CABLE WILL SOLVE ANY PROBLEM
ALSO SOME T.V SETS ARE JUST LIKE THE PLUG AND PLAY YOU HAVE WITH COMPUTERS, ONCE THE RIGHT CABLE IS CONNECTED AND YOU CHANG TV INPUT FROM YOUR REMOTE IT WILL PICK UP YOUR DVD
Jun 12, 2008 | Samsung Televison & Video
MPEG4 HDD Player
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included)
vk1_3.jpg To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDE hard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
vk1_2.jpg Specifications:
  • Compatible with 2.5" IDE hard disk up to 500GB (not included)
  • It support NTFS and FAT32 formats
  • AV out to TV directly, VGA out to Monitor
  • When connected to your Computer, Do not connect your Power Supply
  • When connected to TV,it need power supply ( included,and which is compatible with your country)
  • Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
  • Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
  • Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
  • Key button and Remote control operation
  • Supports TV type: PAL and NTSC
  • Audio outputs: stereo 2-ch (RCA)
  • Supports OS: Windows 98/98SE/2000/ME/XP
  • Portable design :132 x 80 x 19 mm
  • weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
Jan 29, 2008 | Computers & Internet
TruTech PLV16320 Television Logo
189 people viewed this question
Top TruTech Televison & Video Experts
matt martin
matt martin
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
