Question about JVC GR-D250 Mini DV Digital Camcorder
Lens problem lens cap keeps on even its not
  • 156 Answers
Replace CCD base assumbly and check
Posted on Feb 28, 2008
How do I re-set a 10.1megopixel c1033
Chances are something is blocking the lens. It could be a lens cap, or your finger, or even a grain of dust or sand.
Here's the best first course of action:
1. Turn off the camera
2. Blow sharply into the areas around the lens/lens cap.
3. Turn it on again and see if that resolves the problem. Be sure nothing is physically obstructing the lens. (No lens cap, no finger, etc.)
4. If blowing doesn't work, try using a can of compressed air like you would buy at an office supply store, and blow out the area around the lens and lens housing. Chances are, if nothing was obstructing the lens that you could see, it might be a bit of dust or sand. Even a little sand can totally screw up the lens and keep it from moving in or out.
5. If this doesn't work, you should take your camera to a camera shop and have it professionally inspected and cleaned. Check out how much this will cost, though, before you do -- it might not make sense to pay what they want to charge, versus just buying a new camera.
May 05, 2012 | GE C1033 Digital Camera
When turn camera on get message turn camera off then turn camera on again. did that and repeatedly get same message.
Check to see if your lens cap is on. If the cap is on, the lens cannot extend and you will get that message. If your lens cap is off, check to see if there is something impeding the lens and keeping it from extending. Your camera may "think" the lens cap needs to be removed.
Jul 28, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
LENS-CAPPED appear , even though the cap had been taken off already. can't record. why?
Usually this message (with the cap actually off!) means that the internal iris is stuck closed. This can occur for many reasons. The problem is that this is not a DIY repair. You can try tapping the lens assembly with your finger. Sometimes the vibration of that tapping will release the iris. If that fails, then the only way to resolev it is to gain access to the assembly inside the camera. Again, this is not a DIY repair unless you have previous experience with camera repair. The internal cables and parts are easily damaged. When attempting the "tapping", strike the camera near the printing that is close to the visible lens. Please be gentle, do not strike hard, just a firm tap.
Keep us posted on your progress,
Dan
Dec 13, 2010 | JVC Cybercam GR-D93 Mini DV Digital...
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Wide angle cap vs wide angle lens
The cap is a plastic disk, usually black or silver, that snaps on at the end of the lens to keep the lens clean. Some lenses have two caps, one for each end when not attached to the camera.
Some cameras don't use a "loose" cap; those cameras generally retract the lens into the camera body and "close" a door in front of the lens.
Many, if not most, camera users do not use a cap (my guess).
The wide angle lens is generally an "optional" lens that can be used for group or scenery pictures when you want to shoot a "wide" picture. A "normal" lens is generally around 50mm (plus / minus 5mm). A wide lens is anywhere from 17mm to 24mm (or so).
I recommend obtaining a wide lens... with a cap.
Hope this helps!
Sep 10, 2009 | Casio Exilim EX-Z57 Digital Camera
It says lens cap when lens cap is removed
KEEP UR HAND CLOSE TO THE LENSES, FACE DETECTION IS ACTIVATED OR U RA MAKING PICTURES OR VIDEOS IN THE NIGHT. TRY WHERE THERE IS LIGHT
Aug 09, 2009 | JVC Everio GZ-MG20 Camcorder
Display is black even after removing the lens cap
See my post of before. I just knocked the camera on the floor by mistake and it miraculously started working again after years. Shows it must be mechanical and not related to software.
Jan 28, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Lens cap still on
Hi, this sounds like CCD chip fault.
JVC will repair this for free if your camcorder was sold between 2002 - 2004 as the CCD chips were faulty before they were fitted into the cameras.
go to them main JVC site and click "support" for details, offer runs until 31/12/08
Sep 27, 2008 | JVC GR-D20EK Camcorder
700x digital zoom mini dv - focus problems
Hi, its your ccd sensor. JVC are doing a free repair until June 2008. Visit their website for contact number and more information.
Dec 31, 2007 | JVC Everio GZ-MG37 Camcorder
Lost lens cap
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Sep 18, 2007 | Konica Minolta DiMAGE Z20 Digital Camera
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
65 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
