Question about Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 suddenly stops working in route to destination
I was on a trip to Mississippi--Garmin got me there fine. On my way home, I was on a major highway and it just suddenly told me to turn on a street that was not there...Then on the Garmin device, the car left the road and was off in the 'black area'....The Garmin continued to tell me to make turns that were not available. I finally cut if off and relied on my memory to get me home. I turned the Garmin on again when I was closer to my destination and it was fine. Any suggestions?
Probably lost the satillite temporarily
Posted on Feb 16, 2008
How do I change a route on my garmin rv760 from the route the gps picks
There should be a built in trip planner app to set up your trip. If it is a long trip and you don't like the route just add a stop for gas or food along the route you want to take. If it is a short trip then get over the fact it is recommending something different, mute, it and drive how you want to go. It is a computer and does not know what you may know. As an alternative, add a via point by telling it a new destination while it already has one. For via points remember to work backwards. Final destination, then next to last and so on.
Feb 24, 2015 | Garmin Nuvi 760 Car GPS Receiver
Cannot Calculate the route - Garmin Nuvi 3760
My probleme:
When you want to select (established) a route (Finding Location or Planing a Trip) the device machine can not calculate route and displays the following message: "Route waypoint memory is full". The device is Garmin 3760T.
I found the solution:
1. Start the device.
2. Touch "Wiew Map or Map"
3. Touch on bottom right of screen (Speed)
4. Hold your finger on top center of screen for 5-10 seconds (the speed semicircle between Trip A and Trip B). The unit would go into "Diagnostic Page".
5. Select "Clear all user data" and confirm.
Warning: will erase all user-selected data (Home, Recently Found, Favorites, Trip Planner, ....).
Mar 04, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Garmin Nuvi 760 gps Unable to calculate route No roads near starting point
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Aug 02, 2010 | Garmin Nuvi 660 GPS Receiver
I am trying to put in multiple destinations for the same trip. When I try to put in my second destination it keeps going back to my home site not my first destination. It starts the trip for my second...
The Nuvi you have does not support multiple destinations in a route. you can have 1 destination and 1 via point. So if you are going to a destination and you need to add a stop in the route, you can add the 2nd point to go to and then continue to the original destination.
Feb 21, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Garmin 660 will no longer plot a destination...
Have you loaded a lot of JPGs or MP3s on the internal memory? If so, you have reduced the amount of memory available to the 660's OS. Not sure if the 660 stores calculated routes directly to the internal flash memory, but it is very likely, since it keeps your route when you power it down.
To unload the internal memory, consider buying an SD card - they are cheap right now. As a matter of fact, I just ordered an 8GB SD card for my 660 from Amazon for $13. The 4GB and 2GB cards are available for about $7 and $3 respectively. Drrrrrt cheap!
You can access the internal memory of the 660 on your computer with the USB cable you got with the 660. The two folders to focus on are the JPEG and MP3 folders. Simply copy these folders' contents to the root directory of the SD card, and then go into each folder in the GPS memory and delete the MP3s and JPEGs you added - should work better. The 660 will recognize the files on the card if left in folders named identically to the folders in the internal memory.
If you didn't add any content to the internal memory, that is a different issue altogether, probably something to discuss with Garmin. Could be as simple as upgrading the firmware. Make sure you select the correct version though, or it could be a fancy brick! Go here for the nuvi 660:
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=164&pID=31946
Good luck, and I hope this helped!
Jan 05, 2009 | Garmin Nuvi 660 GPS Receiver
Refuses to consider certain border crossings
does it include the map for North America and Canada?
you may have to reload it
try using shortest route
Aug 12, 2008 | Garmin Nuvi 660 GPS Receiver
Return trip
Have you selected how you want to get there, shortest distance, or fastest trip. You can set these under the wrench menu, If you aim for fastest, usually it will select all highway, if you select shortest distance it will calculate a trip that will drag you through every nook and cranny, usually quite entertaing (sightseeing)
May 03, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 660 not working
1-Check if you have 500 waypoints, Thats the maximum.
Be sure you delete the recents search via the menu. the recent use when you did a search for a place or adress, just delete.
2- could you confirm both of you if you did not add any other maps into the units ?
3- How many MP3 you have into the GARMIN files ?
Need this to answer your question properly ?
It should not happen if you did not overload the unit 660.
Everything has a maximum who is published by the manufacturer.
Best regards
Dec 26, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
127 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
