Question about Hitachi 51SWX20B 51" Rear Projection Television
Help please I changed the convergence IC's and have the same problem. Please look at the picture I attached to the post. Thanks, Clayton
  • 1 more comment
  • PsychoDad Feb 11, 2008
    Yes on the magic focus and no on the resitors. I have the service manual, what resistors should I check?
    Thanks,
    Clayton
    Great, I'll check them. Do you want me to email the PDF of the manual for your collection?
    I sent it. I could dee if one of those resisitors were bad/going bad and it's resistance increased it would lower the deflection voltage +/- from zero point in the center of the screen., correct?
    Clay
    President:
  • 4,402 Answers
Have you done a magic focus since replacing the ic? did you check the 6 resisters?
Posted on Feb 11, 2008
  • Cary Farah
    Cary Farah Feb 11, 2008
    i don't have a service manual but they range from 3.9ohms down
    they are off the output of the convergence amp ic's, lift one leg out of the circuit.
  • Cary Farah
    sure, to this serviceman36 at gmail dot com
Bow tie screen
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With any Projection Television that has a damaged convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Jan 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
The rear projection lamps appear to be out of alignment and the Magic focus is not correcting the problem.
Their site is
You can also try
asnowman
Jan 28, 2010 | Hitachi 43UWX10B 43" Rear Projection...
My tv has double picture how do i fix it
Their site is
You can also try
asnowman
Jan 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Convergence, tv color off and not so clear anymore
Their site is
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue. I am doing this for free.
asnowman
Dec 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Picture looks like it is doubled, and has a blue and green tint to it. When green bulb is covered up picture realigns and looks pretty good, does it need a bulb replaced?
With any Projection Television that has a damaged or interment convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
Their site is
You can also try
asnowman
Nov 30, 2009 | Panasonic Televison & Video
Convergance problem on lower half of screen.smeared red and orange double vision,but only on bottom ofscreen.top appears out of focus,but not double visioned.
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The part(below) Number is from Toshiba, they provide good advice on replacement parts. Make sure what type of IC's your TV uses first. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
Thanks for choosing FixYA, Big Irish.
Nov 23, 2009 | Televison & Video
Colors are off and the picture is concaved. Tried to flash focus with no change. Picture is narrower in the middle and the colors are seperated.
Your symptoms sounds like a damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 02, 2009 | Sony Televison & Video
Convergance IC 52 Inch Mitsubishi
If its the early mitsubishi they are located on the far left side of the chassis looking in the back they are attached to a large heat sink. If you post the model number of your set I can post the correct ICs that you need as well as where to get replacements that have free instalation instructions with pictures.
May 20, 2008 | Dell GX270 P4 256/40/48X/XPP/NONE...
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Picture issues, not sure what the problem is, photos posted
It looks to me like the green is sagging down at the top, and this means that one of your convergence IC's has stopped working. Instead of replacing the whole module, locate the convergence IC (Samsung typically uses the STK392-040 IC's) that handles Green Vertical (GV) and replace it. Sometimes there is a fuse next to the IC that looks like a small resistor that opens up too. If you do not have experience changing convergence than have a qualified tech handle it for you.
Jul 03, 2007 | Samsung HCM4215W 42" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
