My panasonic dvd s77 stops during playback
My dvd s77 stops during playback of cd's and dvd's and then starts at the beginning of the disc.
  • lmm1 Feb 11, 2008
    Any pics of the carriage mechanism so i would know what to look for? What lube is used?
    Brigadier General:
  • 6,966 Answers
If this is a common problem to most CDs and DVDs that you are playing, then it could possibly be the slider shafting in the mechanism of the unit. The optical reader/lens laser eye sits atop a carriage that slides on this shaft roughly 2~3cmm in dia and about 6 cm long. This tends to accumulate dirt, grime, dust and cakes the lubrication. Rebuilding normally solves the problem. This would call for opening the unit to gain access, clean with alcohol or contact spray, relube and dry test by sliding the carriage which should move freely to and fro.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 11, 2008
  • Louie  Role
    Louie Role Feb 11, 2008
    Ooops, that should be 2~3mm not cm. Any light lubricant/grease should do just fine but should not be that much.
  • Louie  Role
    Additionally, it may be blockage of some sort in the toothed railing in some versions/models.
Unlock code
can u tell if the dvd movies are in a particular format
Apr 06, 2008 | Panasonic DVD-S77 DVD PLAYER
I still have the same problem ct mode will not go away on my sc-pt750
You're under the impression that we see an historical thread that connects this request with a previous one. We don't. Start over. Tell us what is wrong and what you've done already.
This previous Fixya post addresses something similar.
http://www.fixya.com/support/t1342919-sc_pt750_screen_says_ct_mode_wont_change
Or is it "CD" mode??
There's a discussion of "CD Mode" on page 16 of the manual.
"If all loaded discs are DVDs, CD Mode does not work.
HighMAT menus and Video CD playback control are disabled.
You cannot turn CD Mode on or off during program or random mode.
If you want to play a DVD, press [CD MODE] again while stopped to cancel CD Mode. (CD Mode is also canceled when you switch the unit to standby, select another source, or change the disc in the play position.)
DVD and JPEG are skipped without being played."
STCT
MODE
Sep 06, 2011 | Panasonic Home Theater System System
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    My cd player says locked when i try ejecting the disc trays it is a jvc uxs77
    on the one I have you hold down the stop button and the eject button at the same time to unlock but it is a diffrent model maybe it will work.
    Oct 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
    How can I burn a CD with a movie file to use on a DVD player?
    First of all do you have the right kkind of dvd player?
    I have a dvd player that plays DIVX movies, so I use Roxio software and burn a data cd of an avi. file. From my understanding AVI, DIVX, & MP4 can be read as a divx. Make sure you close you secission on the disc or it wont play.
    Sep 19, 2009 | Panasonic DVD-S77 DVD PLAYER
    JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
    it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
    May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
    Model
    is your problem solved
    DVD Player makes a slight "tick,tick" sound during playback
    I would certainly take the unit back cause that noise could be the tracking or focus coils making that noise as they are being overdriver. This could cause the unit to fail prematurly. Its not an adjustment that you can do your self, it takes special equipment and disc
    Jun 01, 2006 | Panasonic DVD-S29 DVD Player
    395 people viewed this question
     Grubhead
    Grubhead
