Question about Frigidaire FEF366 Electric Kitchen Range
Figidaire oven light will not turn off
HELP!!! We have a self cleaning range and used the cleaner for the first time today. This model has the oven light come on only when the door is opened. When I started the self cleaner the light came on and it stayed on. How do I get the light to go off??? I stopped the cycle before it was done because we had to leave the house. Tried unplugging it to see if something would reset...Light is still on, won't go off. Please Help
  • ALBO462 Mar 03, 2008
    My Frigidaire GLEF396CSA oven light stays on even with the door closed. I removed the switch on the door it still stays on.
This model does have a switch to turn the light on and off. The switch does not work. when i turn the light off it still stays on.
Posted on Mar 04, 2008
  • Frigidaire Master
  • 2,651 Answers
Sounds like you do indeed have a bad door/light switch 316209900, replace it though dont remove it. also just give a check along the top of control panel some models actually have a oven light switch along the top.
How do i start self cleaning oven
To Self-Clean:
1. Press SELF CLEAN to set the clean time to HI (4 hours
30 minutes).
2. Press the TEMP/TIME "+" or "-" keypads to cycle between LO
and HI clean time.
3. Press START.
The oven door will automatically lock. The CLEAN indicator
light will be displayed. The time remaining will also be
4. When the self-clean cycle is complete and the oven cools, the
CLEAN indicator light will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth
Remove the broiler pan, grid, cookware and bakeware, all
cooking utensils, oven racks and aluminum foil and, on some
models, the temperature probe from the oven
Dec 07, 2012 | Maytag MGR5751AD Gas Kitchen Range
How to use self clean for oven
Turn off the oven light and remove all pans and racks from the oven. Clean the oven and door frames with a non-abrasive cleaner. Do not clean the door gasket. Remove any excess grease or debris from the oven bottom.
Close the door and move the lock lever to the right. The "Lock" indicator will light. Press the "Clean" pad, then press the up or down arrows on the "Set" pad to adjust the cleaning time: two hours for light soil, three hours for medium soil and four hours for heavy soil.
Cancel self-cleaning after it has started by pressing "Cancel."
Wait one hour after the cleaning cycle has ended for the "Lock" indicator to go out. Unlock the door.
Clean the oven racks with soapy water and a scouring pad and put them back in the oven.
Sep 25, 2010 | Maytag MGR5752BD Gas Range
My self cleaning oven will not lock, so I am assuming it is broken. My oven needs to be cleaned. Since you can not use an oven cleaner on it, what can I use to clean it?
Please carefully apply the below instruction to clean up your range
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    thank you.
    Sep 20, 2010 | Hotpoint RB757 Electric Kitchen Range
    I went to use the auto clean on my oven....turned the knob to "auto clean" then turned the oven door latch to the right to lock it. i found out the auto clean took 4 hours (don't have time to do it today)...
    Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
    Sep 08, 2010 | Hotpoint RB787 Electric Kitchen Range
    I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    My range is actually the RGB746 self cleaning gas
    oven don't stay on and it takes a long time to heat up
    Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
    That's fairly typical but I would suggest removing the shelves and cleaning those with oven cleaner if they need it at all. Expect the door to remain locked for additional hours for safety.
    The temperature rises to > 900 degrees F and is necessary to start the catalytic process that consumes the crud.
    Sorry I didn't see your message earlier-
    Nov 16, 2008 | Magic Chef 31000 Gas Kitchen Range
    Kenmore gas range trouble
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
    Hotpoint self-cleaning oven
      I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
    Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
    Frigidaire FEF366 Electric Kitchen Range Logo
    170 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Paul Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
