Question about Mitsubishi VS-6047 60" Rear Projection Television
Mitsubishi 60" Model VS-6047
Push power buttom, green light shows and it clicks itself off without seeing screen or hearing audio.
  • 2 more comments
  • Randy Bates
    Randy Bates Mar 29, 2008
    TURN ON ,,GREEN LIGHT COMES ON FOR 4 SECONDS ,,THEN TURNS OFF,,WILL NOT POWER UP
  • Sazsha2008 May 20, 2008
    I have the exact same problem. Have not called a TV repair place yet. What have you discovered?
  • Junior64 Aug 31, 2008
    I have the same problem with my Mitsubishi 60" 6047. When you push the power botton it truns on but then shuts itself off without any sound or picture.
  • VonZeppelen
    VonZeppelen Feb 20, 2009
    Same problem here. Just after watching a movie, the picture went out. I found a website, partstore.com that sells all or most of the boards but I'm hoping that someone has fixed one already and can tell me which board to order. The main board is $305.95 refurbished. Worth it? I think so.
  • 126 Answers
Going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Posted on Feb 19, 2008
Why does my sound come on but no picture, then picture after several minutes?Mitsubishi vs-6047
it sounds like a component is going bad. i have known a flyback transformer to act like this before going out
Nov 10, 2009 | Mitsubishi VS-6047 60" Rear Projection...
The tv clicks on but it clicks right back off why? its a vs 6047 model mitsubishi
I am not familiar with this particular TV model, but what you describe is usually the power supply switching the heavy current circuit on and then switching it off in a few seconds since it does not detect the high voltage it expects and presumes there's been a short circuit somewhere.
Most of the times it's not actually a short circuit, it's either a blown fuse or an element that went completely open and prevents the power supply from working.
Nov 03, 2009 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi Big Screen TV Model VS-6051 will not turn on. I hear a clicking sound when I unplug it from the wall but it still does not turn on.I have tried using an alternative power source and it still...
hello VS6051 POWER SUPPLY PULSATES ON/OFF IC9A1(267P062010)
VS6051 VZ2 POOR START L9A30(BEAD ON LEG OF R9A21)-R9A22 TO 1.2K, R9A12 TO 15K,C9A15 TO 330UF
VS6051 VZ2 POOR START,ADD 22UF/100V PARALLEL W/C9A17
VS6051 VZ2 WILL NOT POWER ON D9A00(264P102020) IC9A0(267P112050)
Sep 19, 2009 | Mitsubishi VS-60111 60" Rear Projection...
My vs-6055 you can hear it click but it wont turn on
check q570 if shorted replace it,also regulator ic401 goes bad along with c402 100mf/50volt electrolytic cap
Sep 01, 2009 | Mitsubishi VS-6055 60" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
TV problems
I have a mitsubishi HDTV 1080 Integrated and the speakers are off and I can't get it back on
May 14, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi vs-6047 60 in
pull the front panel off, remove the 4 screws holding the inner panel on , then with a screwdriver gently touch the wires leading to each of the the projector bulbs one of these is not getting a good connection , it is the one that has about 6 wires leading from it
May 12, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Televison & Video Logo
232 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
