Question about Dell (002TR) Motherboard
Dell dimension 5150 - start up
My dell desktop won't start up. it was left on standby over night a then whilst i was out next day it seems to have broken. there is power, as it tries to start, but it does not recognise the keyboard or screen. it makes strange harsh beep-like noises for about 30 seconds, then does nothing at all. the 3 and 4 lights are lit up on the front and a green light is on the motherboard.
does anybody have an idea as to what is wrong? if so i'd appreciate any help!
thanks, John
  • 1 more comment
  • jonnyjive Feb 13, 2008
    yeah i tried all that - ended up calling dell and they ran me through resetting the memory - seemed to do the trick - i think it had been on too long... thanks for the suggestion though
  • skalolo Jun 05, 2008
    my dell computer does not even start to boot! It was just working properly, when I came back trying to start it, it is not starting. What have I to do?
  • branree27 Jan 06, 2009
    computer will not boot up the light comes on and there is a green light that comes on the motherboard
  • 983 Answers
You may be knowing there are many types of beeps which made as standard for all pc ...
if the pc beeps for 30 seconds and then starts means there is no input device connected ...(here the standard input device is keyboard)
so c the keyboard is connected properly or not try reconnecting it...
and about the display when sometimes computer makes beeping sound the screen is not displayed ... after connecting that just try is it working or not.. if problem persists then just check the cables of the monitor too... try reconnecting them also.....
Posted on Feb 11, 2008
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Max hard drive that can be fitted to a dell dimension 5150 thanks tom
Sir your Dell dimension 5150 can be expanded with maximum 250 GB of hard drive .
Thanks.
Have great day.
Oct 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 Boot Problems!
You can probably try two things here.
1) Go to the BIOS and reset the defaults.
2) Clear NVRAM from your Dell computer. Here is how you do it.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4C1BF720A3E78F92E040A68F5A2811BE&journalid=7788D9829DCAA7C8E040AE0AB6E12FA2&Query=bnZyYW0=&SystemID=DIMENSION+5150/E510&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 boot up difficulties - just goes to the Dell screen and then nothing - a little blinking white dash in the upper left corner. I usually hit f12 to boot from there, but it seems that...
try to run diags, press f12 when booting the choose utility partiton. check for any error on your HDD but it seems like its an OS issue so all you need to do is to uninstall and reinstall your OS
Sep 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 does not start
Could be a number of things, First take the ram out and then put it back in and see if that helps. next I would unplug any devices not required to start the computer.
You need to be familiar with the inside of the computer to do this.
Most likely suspect however is the power supply.
Jun 19, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell (002TR) Motherboard Logo
843 people viewed this question
Alun Cox
