Question about Pioneer PD-F805 CD Player
The player doesn't take the first CD
When I press the play button, the player takes the second CD, and think it's the number one.
2 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: CD player not allowing insertion of CD
The mechanism is jammed. It will have to be serviced by a repair shop.
Posted on Dec 08, 2007
Getting my aiwa to play cds or cassettes. Bought second hand no instructions .lights up won't play can I get instructions on how to get sound?
You don't state the model, so we are running blind here. It should be fairly obvious. For the CD press the CD button. Then press the door button and put the CD on the tray. Then press play or the door button again. If the CD player works it should play the music. Same with the cassette. Drop the cassette into the holder, push it back in place then press play.
Oct 07, 2017 | Aiwa Audio Players & Recorders
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    How can I programe my DVD Player xv-s332 so that it plays all zones
    Have no dvd or cd in the player
    step 1.unplug the dvd player
    Plug player back in while holding the Open/Close and play buttons on the player
    The word TEST and a number should come up on the player Display
    Step 2.Press 9 on the remote until the display on the player says 00A0 0000 it should take 40seconds of pressing 9 to get to 00A0 0000 as I think its the last code in the sequence.
    step3.Press Standby/on on the remote or player
    Wait 15 seconds
    Turn player back on.
    Let me know if it works.
    (I got this hack from another dvd player the JVC xv-302sl but it should work on the JVC xv-332sl
    Len..
    Oct 14, 2014 | Televison & Video
    Technics SL-MC60 error message: "Take out"
    Hello
    If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
    Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
    Feb 03, 2012 | Audio Players & Recorders
    I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
    I think that's Demo mode.
    I got stuck there too.
    This is what worked for me:
    1. Power the radio off (hold the power button in top left corner in for several seconds)
    2. Remove face plate
    3. Hold in reset 10 seconds
    4. Press push-menu dial/button 3 or 4 times
    5. Insert cd and hit source to switch to tuner before cd starts
    Not all of these steps may be necessary.
    I suspect having the power off before the reset button was the important part.
    Jul 26, 2011 | Aiwa CDC-X204 CD Player
    I cant play cds on my wharfedale pcd 6200 usb
    I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
    Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
    Might just work?!
    Duncan
    Mar 22, 2009 | Audio Players & Recorders
    CD player won't play after pressing the play button on all tracks
    This problem is usually caused by dust or smog accumulating on the laser lens assembly. Unplug the unit and remove the top cover. Take a cotton swab and wet one end with glass cleaner. Wipe it gently across the lens (do not apply pressure). Use the other end of the swab to dry the lens. Reassemble the unit and test for skipping or non-playing discs.
    Feb 02, 2009 | Audio Players & Recorders
    I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
    I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
    Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
    To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
    Hope this helps. :)
    Oct 18, 2008 | Audio Players & Recorders
    Why won't my cd player eject?
    Hi Darla ,
    If your problem is with new cd's your trying to play then the try this. New cd's often have around the inner and outter edges and if such disc is used, this may be the reason why it wont play. What you do is take a pencil and use the side of the pencil to rub the edges of the cd. It should clear it up. Now if your problem if that it wont let the cd come out the only thing i can think of is to press and hold the EJECT button and CD button at the same time for more than two seconds. Good Luck =)
    Mar 03, 2008 | JVC KD-G120 CD Player
    JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
    Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
    Sep 08, 2007 | JVC KD-G110 CD Player
    Pioneer PD-F805 CD Player Logo
    23 people viewed this question
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ian Summerfield
    Ian Summerfield
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
