Question about Epson Stylus CX9400 Photo Printer
Help 'will this fax with dsl i do not have a phone line we use cell phone' inside Epson Stylus CX9400 Photo Printer
    Scholar:
  • 84 Answers
No.you need dial tone to send faxes. dsl is for computer use.
wg
Posted on Feb 11, 2008
How to open up an epson 9400fax to clean
Page 16 of the manual shows you how to properly clean your Epson Stylus CX9400.You can view the manual here:
http://www.manualbuddy.com/3570/epson-stylus-cx9400-fax-user-manual
Jan 30, 2013 | Epson Stylus CX9400 Photo Printer
How do I remove and install a new black in cartidge in a CX9400 FAX/Printer
Look on page 36 of this manual.
Stylus CX9400 / CX9475 - Quick GuidePlease gave a vote, it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Mar 13, 2010 | Epson Stylus CX9400 Photo Printer
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
ATT u-verse phone which is voip and HP 6180 All in One
Ask ATT if they have available a Digital to Antalog converter that can use for with your  fax machine.
Jan 23, 2009 | Epson Stylus CX9400 Photo Printer
Cannot send out faxes
Directly from the wall, phone line should be connected to to Line port at the back of the printer and answering machine should be connected to EXT. port from the back of the printer. Make sure on the fax setting on the printer that you have all the info already ( ur number and stuffs), communication setting on the printer, drd set to all, ecm to off, v.34 to off, rings to answer 6 and dial tone detection to off. and answering machine distinctive ring pattern should be set to 4rings.
And since you are using DSL make sure that line from wall should have a filter then connect it to LINE port at the back of printer...
Apr 03, 2008 | Epson Stylus CX9400 Photo Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
