Question about Panasonic CT-32SX31 32" TV
Off on button
The off on button seems spongy and wont turn on.
    Genius:
  • Panasonic Master
  • 1,550 Answers
Change the pushbutton of the power
Posted on Mar 14, 2008
After bleeding brakes peddle still seems spongie
Most likely. Check the brake adjusters to see if they move freely. Correct adjustment is tighten until you can't turn wheel any more then back off a few clicks just enough to allow the wheel to move with a slight drag on it.
Aug 22, 2016 | 1964 Cadillac DeVille
Spongy gas pedal
You will need to open the hood and have someone watch the throttle as you push the gas pedal, see if the throttle arm moves as you push on the pedal, this may be due to a bad cable or it may be off its holding bracket or loose. start with this test.
Jun 29, 2013 | 1997 Oldsmobile Cutlass Supreme
2001 hyundai accent clutch feels spongy and the
seems to be a worn clutch... Take/Tow your vehicle to an authorized Hyundai dealership and pay the diagnostic fee... they will tell you exactly what the problem is and the cost of parts/labor to fix it... at least this way you'll know what the problem is and what's required to fix it.
Sep 23, 2009 | 2001 Hyundai Accent
My LG neon wont turn on
plz check ur battery or chang it
Sep 03, 2009 | LG RUMOR Cellular Phone
Dryer will not turn on.
Could be start switch but unlikely. Check these things first...
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Jun 04, 2009 | Dryers
Spongy brakes 1996 Chevy C1500
You can adjust the shoes outward on the rear by removing the wheels and drums, then above the axle but below the wheel cylinder you will see an arm that is horizontal, pushing both of the shoes outwards. There should be an adjustment nut that you can turn to extend the arm to push the shoes out.
Apr 22, 2009 | 1996 Chevrolet C1500
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Spongy breaks
The rear brakes need to be adjusted
Nov 21, 2008 | 2000 Dodge Caravan
How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Aug 07, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ignition barrel
Tried turning the wheel a little to disengage the lock function?
Jul 07, 2008 | 1989 Nissan Pulsar
Panasonic CT-32SX31 32" TV Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
