Pioneer sd-p5065 won't power up
When I plug in the power, the relays click on then off. Some times I can plug it in, hit the power button and get the same results. I have pulled the power supply board and checked and resoldered cold connections. Found 1 cracked soldier, but it still does the same.
This is manufactured in 4-92 , model sd-p5065 pioneer.
I can't find an online manual. I have a little knowhow of the basics. I can't see any burnt capasitors or popped resistors, but if I could get help to test volt and ohlm levels, and led in the right direction, I think it would be doable.
I'm trying to get this working to hook it up as a dedicted gaming tv.
Please advise. Larry lrcargill@comcast.net
  • chujudilo Apr 14, 2008
    I have the same problem with mine, can anyone help me?
    Brigadier General:
  • 6,966 Answers
Good hints Paul, I had him on Live Chat for a while but lost him somewhere. We parted with him checking the HOuts off board since he has access to a soldering iron and a desolderer. I have initially briefed him on the B-C-E forward and reverse testing as well as the possibility of the B-E resistor and C-E shunt diode which might throw him off.
@ LRCARGILL,
Any developments with your unit?
Cheers all.
Posted on Feb 11, 2008
  • 4,102 Answers
Hi i tried answering your chat session but didnt answer quick enough the best place to look is near where the power lead goes into the telly where it goes into the board you will find transistors these will need checking as the do cause the kind of problem your having so check these you can find out the sort of readings you should get by using search engine and type in testing transistors this should give you some sort of idea on what results you should get ok.
Also have you typed in schematics for (then give make and model )see if this locates the schematics for your telly often this helps and does find them i have came across all the ones i need this way
I have a Pioneer VSX-515-K A/V Reciever. When I plug it in the power relay clicks continuously. I don't have the schematic to troubleshoot the circuit. I just want to make sure it is the relay that's bad...
A bad relay won't pick and release itself. You need to find the cause.
Here's the Service manual.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-515_RRV3092.pdf
Page 66and 67 have a timing sequences for power up and down.
Pages 72 and 73 describe a possible loops - DC abnormality and Fan Stopped.
Mar 16, 2011 | Pioneer VSX-515 Receiver
Pioneer SD-P5181 will not power up
pioneer sd p5181 will not power up redlight on stand by works when i hit the power button makes a funny sound and then nothing anyone plz!!!! help thnks
Jul 11, 2009 | Pioneer Televison & Video
PIONEER DJM 600 . NO POWER.
I have the same problem, One day I open the djm-600 for replace the jack whole (easy), then of this when i close the mixer my pioneer died, but when I push the power button I can listen a little sound like ¿voltage running? Please Help !!!
Thanks
pd: sorry for my bad english
Nov 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Pioneer pro119 power on off
If You go To the link i'm enclosing we have your service manual for your set for 10.99 and if you click on the contact us section and provide your email address we will email the manual to you as well as info on how to enter into a chat window to help you diagnose your set. Just click on the section for Pioneer we have your manual. I am one of their support techs. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 12, 2008 | Televison & Video
Pioneer rear projection tv in standby mode
if the relay clicks when pressing power check C258 in video assy.
Aug 14, 2007 | Pioneer SD-P62A3-K 62" Rear Projection...
Turning on SD-P403 Pioneer projection tv
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Oct 30, 2006 | Pioneer SD-P50A3Q 50" Rear Projection...
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
