Question about Pitco Frialator SG14 Deep Fryer
Pilot light won't stay lit
The pilot light wouldn't light. I replaced the thermocouple, now I can get the pilot to light, the pilot/heat will start, then after 10 minutes or so, I have no flame or pilot light.
Thoughts??
  • 1 more comment
  • taeyona May 08, 2008
    i've have already replaced all parts but pilot lights. but after 30seconds it wont stay light
  • Anonymous Mar 21, 2014
    Auto pilot light
  • Anonymous Mar 29, 2014
    Gas is on and running but the pilot light does not stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Posted on Feb 13, 2008
My pilot light won't stay light
Most often, this is a faulty thermocouple. Replace it, but first be sure the pilot flame is actually heating the thermocouple. If it is not, it will not stay lit. Sometimes they fall down out of it's holding bracket or just go bad. A lazy yellow pilot flame means the pilot orifice is dirty and needs to be cleaned. If the pilot flame is a string blue color, then replace the thermocouple.
Mar 17, 2015 | Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
Pilot light keeps going out. can blow it out
When troubleshooting a balky pilot, ensure you don't allow any unburned gas to build up!
Usually a problematic pilot is due to a faulty thermocouple. The thermocouple is a safety device designed to interrupt the flow of gas if the pilot light goes out. When lighting the pilot, you usually have to hold a button in to bypass the thermocouple until the flame heats up the thermocouple and it can allow the passage of gas.
Try replacing the thermocouple - a universal can usually be had for under $10.
Dec 28, 2014 | Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
I have a Dayton 3E290 wall heater that was installed new 30 years ago. The pilot light started to extinguish a few years ago. Gradually this began to occur more frequently. I've changed the...
The pilot assembly may need cleaned out and the orifice cleaned, also the gas valve may need to be replaced, to check for proper voltage from the thermocouple you need a flame source and it takes a meter that can register DC milliamps, and should be 350 to 750 millivolts. Heat the thermocouple with the pilot or other flame source and check, if OK, gas valve is weak.
Nov 02, 2011 | Dayton Gas Furnace Heater
Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
May 06, 2011 | Rheem Water Heaters
I just bought a brand new Kozy World blue flame heater and the pilot light will not stay lit and when it is lit, it goes out as soon as I turn up the nob.
The thermocouple is bad or not aligned properly. It is the metal bar in front of the pilot light. This bar senses the heat put off by the pilot light. If it does not get hot it will not allow the gas to flow. You either need to align it so that it is in front of the pilot light and receives enough heat to allow the gas valve to operate or possibly the thermocouple has gone bad and needs replacing.
It could also be that you are not waiting long enough. The thermocouple must sense the heat for at least one minute or more before it will let the gas valve turn on. Turn everything to off for at least five minutes. Re-light the pilot light and let it burn for at least one minute and then try turning the knob to on.
Nov 25, 2010 | The Companion Group Kozy World Portable...
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
Pitco Frialator SG14 Deep Fryer Logo
1,264 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
