You don't state the manufacturer or model number in your question, thus we cannot answer. I will say that many do, but there is a caveat. If the the VHS tape is a commercially made movie, chances are it has copy protection on it. Most machines will sense this copy protection and will refuse to copy the protected VHS tape to DVD. This was done to prevent piracy. Home recorded tapes and non-protected tapes will usually work ok. Do not confuse write protection with copy protection however. Write protection is merely the tab on the tape that prevents re-recording of the tape. Copy protection is recorded right onto the tape itself and is read by the machine during playback.
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Best guess...put audio cd into DVD side, Video tape into VHS side. Set the VHS to record in SP, Then record the cd to vhs. then when you are done recording on the vhs, put a blank DVD in the recorder side, and press dubb to DVD to get it to record from vhs to Dvd.
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so. via insert the vhs tape and insert the blank dvd in to its tray play the vhs tape and press rec to record on to dvd . although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
I do not think you would have to worry about a way to disable the copy protection that is on the vhs tapes. you are not going to record over them. You are just going to transfer information to the dvd side. jh
