I find that sometimes the part number on the owner's manual can change and them I still do not have the part I need. I suggest if your trying to look for a part call Master Parts at 800-446-1446 or go online at www.masterparts.net. They may be able help make sure you get the right part.
Blower seems to have interuptions in power and sometimes cuts off completely causing the heat pump...
(More)
Blower seems to have interuptions in power and sometimes cuts off completely causing the heat pump to shutdown on high head pressure. Could this be the relay? If so, which one - blower relay or time delay relay?
Sterling model TF-45, thermostat calls for heat, gas valve opens up, thermocupler starts pilot, unit...
(More)
Sterling model TF-45, thermostat calls for heat, gas valve opens up, thermocupler starts pilot, unit fires up only to shut down within 30 seconds or so... I had replaced the high limit a while back, recently replaced the thermocoupler... guy told me to clean the part that sticks into the flame, now I have another problem, the part that I thought he told me to clean is rather fragile and broke off... its shaped like a square horse shoe and is at the end of one of the white tips on the thermo coupler... I'm assuming I need this part...
gu100 gas dosent go to pilot light so it blows up blows out pilot light scares wife cleaned pipes...
(More)
gu100 gas dosent go to pilot light so it blows up blows out pilot light scares wife cleaned pipes didnt put something in wrong
on an old carrier natural gas package unit, the spark ignitor flame come on but the burners dont,...
(More)
ON AN OLD CARRIER NATURAL GAS PACKAGE UNIT, THE SPARK IGNITOR FLAME COME ON BUT THE BURNERS DONT, WHAT COULD BE THE PROBLEM.
on a carrier furnace the ignitor comes on and the burner starts for 30 seconds then drops out. the...
(More)
ON A CARRIER FURNACE THE IGNITOR COMES ON AND THE BURNER STARTS FOR 30 SECONDS THEN DROPS OUT. THE GAS INLET IS FINE AND THE FLAME ROD IS GOOD. WHAT COULD BE THE PROBLEM?
