Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wireless problem When I try to make a change to the settings of my router like changing mac address or open a different port. Everybody else's internet that is on wireless stops working. I hate this problem and have had it for years.
  • 37 Answers
Changing MAC address of a router is usally not nessicary and can cause this issue. ARP (Address Resoution Proticol) maps the IP addresses of ever device on the network to their MAC addresses. To make this process more efficent computers cache (store) this information for quicker retrival. So once your computer has connected to your router it stores it's MAC address. When it trys to connect again, and you've changed the MAC address the computer will still try to connect t a device with the old MAC address which now doesn't exist.
If you find it nessicary to change the MAC address of the router you'll want to clear the ARP cache on the machines that connect to it. To do so type "netsh interface ip delete arpcache" from a command line.
Posted on Feb 23, 2008
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
When I connect my modem to my router, I am unable to access the internet. When the modem is connected directly to the computer, the internet works fine. How can I fix this so I can use my wireless router...
Some Internet Service Providers limit the number of computers that connect to the modem, namely to just ONE. This limiting can be done either "inside" the cable-modem (turn it off to reset the counter to zero) or by the I.S.P. by using a unique identifier,
namely the 'MAC-address' of the network-interface (the router has one MAC-address, and your computer has a different MAC-address).
Contact your ISP, and get Technical Support from them, i.e., disconnect your computer from the modem, connect the router to the modem, and your computer to the router, and get them to "authorize" the MAC-address of the router to get Internet access.
Aug 22, 2010 | D-Link AirPlus DI-524 Wireless Router
My xbox won't connect to my wireless router
Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365.
Also you will need to open the ports on the router.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Click Here for more info
Jan 02, 2010 | Microsoft Wireless Network Adapter Xbox...
Connecting modem to WAN port then any lan port to computer provides no connection. straight from modem to comp is ok.
Make sure comp lan and wan are both activated, Make sure the ethernet cable from modem is plugged into the input slot and NOT 1,2,3,or 4
Then after all is connected, unplug main modem for 10 seconds, plug back in, then do the same with wireless router. 5 minutes later, you should be good to go.
You can access the software of you router by opening up an internet page, and type and hit enter. It should bring you right straight to the router's firmware/software where you can change any settings if desired.
If it asks for username and password, the default is usually admin for both. (see owners manual to be exact)
Nov 16, 2009 | D-Link AirPlus DI-524 Wireless Router
I'm trying to set up a new laptop to my belkin router
When you first setup a wireless router you need to connect the wireless router to the computer with a LAN cable.
Then you open a browser such as Microsoft Internet Explorer and on the address bar you type the IP configuration address of the wireless router eg. for Belkin wireless router it is
Enter the default login name and password.
You should change the password and you should setup WAP or WAP2 encryption (WAP2 is the strongest encryption) and change the SSID and turn off SSID broadcast.
For further wireless protection enable MAC address filtering. The MAC address of the wireless card is entered in the router MAC address filter table, which allows only the wireless card with this MAC address to connect to the router.
The wireless card on the computer needs to be configured with the wireless router's settings. The LAN cable can be removed and the computer communicates wirelessly with the router.
Sep 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a Netwave Base G4 wireless router w/ 4- port switch,trying to network two computers via cable modem using local ports,modem and router not communicating
You need to change the LAN IP address of your router. Open the router's admin through and look for router's IP address or Local IP Address. Change it to and save the settings. Reboot the router after that. If you are on cable internet , you need to do MAC Cloning. Access the router's admin page and look for MAC Clone settings. Enable and clone the PC's Mac Address. Save the settings and power cycle the router and the modem after that.
Aug 02, 2009 | Blitzz Technology (BWA611) Router
Changing nat on xbox live
I had this issue, and solved it recently. Everyone on the internet will tell you to forward ports, or disable the NAT setting, but these never worked for me. As I was about to give up and buy a new router, as a last resort I decided to call tech support. In about 3 minutes they fixed my problem, and it is much easier then port forwarding.
-First go into your 360 network settings and find its mac address.
-In the router settings move to the LAN tab.
-Then go to "dhcp leases".
-Under "current dhcp leases" your 360 should be listed (match the mac address)
-Make a note of the IP address listed for the 360, then delete that lease.
-Now Reserve a new IP address, enter in the MAC address and IP address you wrote down for the 360.
-Check the bypass firewall option (and give it a name if you want) and then add the new entry.
-On the same page, move up to "DMZ Host" find your new entry and click "apply"
-Click the option to reboot your SBG900, then restart your 360, and the NAT should be open.
I hope this helps, if I described it correctly it should be much easier then port forwarding, and more importantly, it should work.
Sep 14, 2008 | Arris SURFboard SBG900 Wireless Router...
Router MAC address
You cant change the mac addresses they are like our ss#'. You can how ever clone your pc's mac to your router. I have several differant routers that I use. one at a time to change my mac addresses.
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
198 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
