Question about NAD C370 2-Channel Amplifier
NAD C370 in protection mode
Hi Friends,
My C370 is not working -- the power LED turns red soon after
power on (it is green for a few seconds), before the speaker relays
ever get engaged.
I found your earlier posts, checked the capacitors. One was open
(c785), the others seemed ok. I replaced all of them except c784
(47u/50V), but the problem remains.
The voltages on the 8 pins of the upc1237 are like the following:
pin 1: 0.6 mV
pin 2: -15 mV
pin 3: 0.7 mV
pin 4: 4.2 V
pin 5: 0 V
pin 6: ~22 V
pin 7: ~30 mV
pin 8: 36.5 V
I suspect the problem is that pin 6 is too high. Shouldn't it be
around 1-2 V? Please enlighten me.
Thanks much and best regards,
DH
  • SmallMonkey Feb 14, 2008
    Hi Dariusz,
    Thank you very much for the advice. Luckily, the big caps on
    my unit are not white, they are purple/light blue.
    Following your advice, I also replaced C784. It helped a little
    but did not solve the problem. Now pin 7 of upc1237 changed
    from ~30mV to 0.65 V. Guess the old C784 had a big leakage,
    and most importantly, pin 7 has an internal short so it cannot
    hold the voltage -- according to the NEC datasheet, pin 7 should
    have about 2.* V.
    I also checked R777 to see if it is broken. No, it is still 57.* K.
    When R777 was disconnected, i measured the resistance
    between pin 7 and ground (pin 5 is connected to ground), it
    was like 1.2 K which seems to explain the 0.65 V.
    Please, if you have a working unit, help to measure the voltages
    on all the pins of the upc1237 and tell me.
    Thank you again and best regards,
    DH
  • 4 Answers
With closed eyes -replace all capacitors on protection PCB All of those caps are overheated and dry out (they lost there capacidance).Note that capacidance meter will not help you at all. Now unit will work. BUT!!! Most important!!! Check four big filter capacitors in the middle of unit!!!! If they are white (NAD 10000uF/80V) DO NOT USE UNIT AT ALL!!!! FIRE HAZARD!!!!! Contact me... Dariusz
Dariusz70@verizon.net
Posted on Feb 13, 2008
  • Dariusz Feb 15, 2008
    well my friend:
    one of your thermal sensors(on heatsink) is open!
    pin 8 on upc1237 should be about 2V not 36!!!
    so your problem is that unit is thermal protection. change one of the defective thermal sensors (one for each channel) or Q728 (2sc1815) that is thermal sensor switch (on main PCB)
    and enjoy
    a-ha my first suggestion (about all cap's) is still valid and good you have change them all.
Nad C350 2 channel Amp continually in protection mode
That could indeed be the issue, but you must check your speakers, wiring, and also the oupt stages for problems. Maybe the prtection circuits are actually doing their job. lol
Hope that helps...
Geno
Apr 02, 2008 | Audio Players & Recorders
Myc370amp turns its self about 15seconds after turn on
Replace 3 capacitors on the protect printboard. (located near the outpt terminals) 50V electrolyt: 4,7uF, 47uf and 10uF. And move the big diode to the back of the printboard (the heat from the diode dries out the capacitors)
Work in 9/10 times ;)
Aug 12, 2009 | NAD C370 2-Channel Amplifier
NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
Apr 11, 2009 | NAD C270 2-Channel Amplifier
Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
HELP PLEASE. NAD 370 JUST DIED...
This could be as simple as a bad connection at the voltage regulator IC or blown output transistors. If you have a multimeter and some experience with electronics repair, this should be fairly straightforward.
Let me know and I'll try to walk you throught the repair.
Dan
Sep 07, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
NAD 304 power indicator
Change resistors 333 & 334 - 47k-1W
Jan 05, 2008 | Audio Players & Recorders
Power light switches to red.
I suggest rechecking the speaker wiring in case there is a small "whisker" of wire touching either the case or adjacent terminal, also check the speaker end of the wires for same. Do you have a pet? I have seen wires chewed partly through by cats (& rabbits)! See the information from the manual below: http://207.228.230.231/manual/NAD-C370.pdf
Jul 26, 2007 | NAD C370 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
1,240 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
