Question about Hauppauge WinTV-Go Plus (85428010335) TV Input
Remote don't work?
My remote doesn't work....even put new batteries in it..still don't work??
  • Anonymous May 03, 2008
    Have the same problem. Remote stopped working.
Hi i am sunilsingla from punjab ok your remote is not working open the remote ok wash the remote plate of use the water and rin soap and dry the plate of air bloer and dry the hot gun ya gas out the water ok call 09810442895
Posted on Feb 29, 2008
Why doesn't trunk open with remote
If you have never replaced the remote's battery, it may be time. The 'coin' type batteries do live long but not forever and mfr.s typically suggest that the lithium cells have a 'shelf life' (unused) of more than five years.
I don't know the construction of your remote so don't know if the battery is user-replaceable or not and if not, the dealers usually take advantage of customers when they can. The batteries alone are cheap costing a few dollars at worst.
If you have the 2nd remote stashed somewhere, you might try it if it has not been in use. Even then, the battery may quickly be depleted in the spare too.
May 27, 2012 | 1999 Buick Century
On my 98 corolla the radio clock and dome light doesn't work. But when I put the fuse in all that works but the alarm goes off. Don't have original key or remote for the car. Is there away to fix...
leave the fuse in have someone disconnect old alarm
and get a new one. is gonna be more expensive to purchase
the remote than to get a new alarm.
(California of coors).
Apr 21, 2012 | 1998 Toyota Corolla
Wii remote not working?
You got to sync the remote with your console to activate the remote
Aug 09, 2017 | Nintendo Wii Console
Sharp GA219SA doesn't work
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
Oct 24, 2011 | Sharp GA219SA Remote Control
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
It don't work even the battery is new
If the remote is not working,try to open the remote and check the battery terminal the one that is connected in the pcb if loosed, then if you have a cellphone with a camera, point the sensor in the camera lens then press any button, then try to look the monitor of your cellphone you will notice that their is a glowing red light it indicates that the sensor is in good condition if you do not see anything try to replace the sensor.
Jun 24, 2011 | Televison & Video
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
I have a kelvinator air-coditioner and the remote doesn't work 6711A20011E is the number on the back as well as N216 can I buy one somewhere I'm from sydney.2210 I have changed battery serveral times and...
I am trying to work out the same thing. The airconditioner doesn't seem to have a part number on it. The only place I have found that sells remote controls is
http://spares.bigwarehouse.com.au/product_info.php?cPath=64867_69567_69609&products_id=1617902
but that seems to be part number 671120011A. I don't know if it would work properly.
I don't even know if a new remote control will fix the problem. But I guess I'll have to try.
Feb 16, 2011 | Heating & Cooling
THE REMOTE STARTER DOESN.T WORK AT ALL. tHE STARTER DOESN;T WORK OR THE ALARM OR OPENING TRUNK OR EVEN LOCKING OR UNLOCKING THE DOORS. i RECENTLY GOT A NEW BATTERY FRIOM THE PONTIAC DEALER HOPING TO FIX...
have you checked if the battery is placed properly in the key.when you press the remote alight on the key should glow.if not so then check the key battery.if fine then the cause is elsewhere.
Jan 02, 2011 | Pontiac Grand Prix Cars & Trucks
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Hauppauge WinTV-Go Plus (85428010335) TV Input Logo
88 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
