Question about Brother HL 1440 Laser Printer
Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Hi gentlemen;
There is paper jam on my brother laser printer HL 2040.
After removing all jam paper, that printer is still not working, with the alarm paper RED LIGHT which is continuing in FLASHING STATUS.
Please show me how to fix the cited problem
My regards
Francis Phu
714-715-6412
fphu@yahoo.com
********************************************************************************8
fp ohu@yahoo.com :please disregard this line. thks
  • 2 more comments
  • Aman Jun 16, 2013
    I try all the below solution but my printer still jam after 2-3 prints
  • Anonymous Mar 12, 2014
    I have a paper jam for a brother lc51 series printer
  • Anonymous Mar 13, 2014
    paper continually jams - both back and front
  • Anonymous Mar 17, 2014
    brother hl4040cdn laser printer printer jam
  • 21 Answers
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Posted on Feb 11, 2008
This happened to me; I thought I'd cleared out the jam and got really frustrated - but it turned out there was a tiny bit of torn paper stuck in the print cartridge that I hadn't noticed. So, like everyone says, make sure you check everything out really carefully.
Posted on May 30, 2011
**** use are stupid, open the tray at the front and back and take the paper out, obviously the printer is telling u the paper is stuck so unstick it ******* dead
Posted on Aug 25, 2008
  • rowena keefe Mar 21, 2011
    Perhaps re-read her question: paper jam was cleared and error lights stayed on! Hence, not a paper jam problem but something else.
    I had the same problem, cleared all paper, blew it out, re-installed drivers, cleaned the toner drum, turned it off and on a dozen times, tried updating firmware (no luck) and tried using the manual paper feed.
    Contacted Brother and it's most likely to be that while removing the paper jam, static electricity hit the internal electrodes and has caused an electrical disruption. Hence, irreparable at home unless you're a computer technician.
    They advised the cost of repair would be greater than buying a new one. Sounds okay to me, but I just got new toner and don't want to waste it!
Besides your helpful
there are extra doing steps to make my printer back to normal:
- Remove completely the unit toner cartridge, check paper jammed in that unit
- open the basck lid of the printer , remove all paper jammed in that arrea
- Blow out the container inside of the printer, to blow away all paper depris and dust.
- re-install unnit toner, close back lid\re-strat printer like your suggestion
Many thanks
Have a Nice Day
FP
714-715-6412
Posted on Feb 13, 2008
  • 42 Answers
You probably still have paper stuck somewhere. Sleep over it and take another look. Another thing to do is to take out the toner cartridge, take out the paper tray, put both of them back in, and press the big button under the flashing light. If it turns to green, you're done.
Posted on Sep 30, 2009
Brother HL-2040 paper light flashes red (and won't print) with plenty of paper in drawer
Check for a p[aper jam somewher in the route or at the single sheet feed entry
Mar 01, 2011 | Brother HL-2040 Laser Printer
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
Red error light is flashing on Brother HL-2040
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_006.html?reg=us&c=us&lang=en&prod=hl5240_all
Hope that helps,
Tiger720
Sep 13, 2009 | Brother HL-2040 Laser Printer
Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
May 27, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Won't feed paper
It has toner? if not replace new one. If it has toner then try to remove the catridge and place it again. This might help you.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Hl 2040 laser printer
Check for a piece of paper caught in the fuser section. Sometimes a small piece will wedge itself in. Vacuum out any residual toner that may be in the paper path.
Dec 01, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Brother HL 1440 Laser Printer Logo
6,487 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
