Question about GE 29385GE1 Corded Phone
Switching from pulse to tone and reverse
Your instruction manual says press menu button until tone/pulse appears----instructions say press arrows to select the mode---the mode comes up on screen --do I dial my number out immediately?----If party answers my call how do I switch back to tone quickly to punch in certain numbers ---at the moment it takes too long and my call is not completed.Im not succeeding in getting into tone mode quick enough
  • rwoggle Feb 13, 2008
    theledge is awesome!
    Scholar:
  • 84 Answers
Once tone/pulse appears there should be a way to hi light/select or choose either one.you must set it into memory. after it is stored, you shouldn't have to set it again before making other calls.
hope this helps
wg
Posted on Feb 11, 2008
  • wilson garcia Feb 13, 2008
    thanks for the compliment!
    glad to have helped.
    wg
I have got a Panasonic KX-TG7220NL. Cannot change from pulse back to tone. How to do that?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Bluetooth-Enabled-Systems/Operating-Instructions/model.KX-TG7622B.O#ts
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/KXTG7622-MUL.PDF
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 18 of the manual for detailed instructions on how to switch between TONE and PULSE dialing. Basically it reads as follows:
Dialing mode
If you cannot make calls, change this setting according to your telephone line service.
The default setting is "Tone".
"Tone": For tone dial service.
"Pulse": For rotary/pulse dial service.
1 - MENU # 120
2 - Use UP / DOWN arrow keys to select the desired setting.
3 - Select SAVE and then OFF
I hope that was helpful to you, good luck and take care.
Joe.
Aug 26, 2011 | Lands Phones
Set on regular and need pulse
Press Menu/Ok - arrow over until you find Base - press Menu/Ok - arrow over until you find Dial Mode - press Menu/Ok - arrow over until you find Pulse or Tone which ever one you want - press Menu/Ok - It will tell you it is saved and you should be good to go.
Aug 19, 2011 | Emerson EMSEM2646WH Phone
How to change voice message on a v-tech phone model cs6229-3 cannot change voice message-lost instructions manuel.(717)866-9262
Press Menu/Select button while phone is not in use.
Press Menuu/Select button to choose Ans System.
Press arrow up or arrow down to choose Ans System Setup, press Menu/Select button.
Press arrow up or arrow down to choose Announcement, press Menu/Select button.
You will hear the prompt "To play press 2, to record press 7. Press 7.
You will hear the prompt "Record after the tone, press 5 when you are done".
You will hear a tone, record your greeting, speaking toward the microphone. Press 5 to end recording.
Your new greeting will be played back automatically, press 5 to end replay, press 2 to start replay again, or press 7 to record again.
Minimum message length- 2 sec
Maximum message length- 90 sec
Below is a link where you can download a copy of the User manual.
http://safemanuals.com/user-guide-instructions-owner-manual/VTECH/CS6229-3-Pre_E
Dec 12, 2010 | Vtech 5.8GHz Analog Cordless Phone
I have a panasonic KX-TGA101s somehow it is switched to pulse, I cant figure out how to switch it back to tone?
press menu
press down key arrow until "Set tel line"
press menu for OK
press menu again for "Dial mode"
Select "Tone"
Raja Thurairajah from Canada
Nov 27, 2010 | Panasonic Lands Phones
Cant get the phone off pulse when dialing model#EM6113-BK
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
Press the "Menu OK" button. Select BASE using "
May 30, 2010 | Emerson EMSEM2646WH Phone
Have an Emerson cordless phone EM6113-BK. We can
On that model you need to press and hold the FLASH button, after it beeps it will be in tone mode and not pulse.
Apr 16, 2010 | Emerson Smartset Clock Radio
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
My VTech 2461 cordless phone is stuck on Pulse
To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
Dec 17, 2008 | Vtech VT 2461 Cordless Phone
From Pulse to tone
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Aug 31, 2007 | GEH5450 Cordless Phone
GE 29385GE1 Corded Phone Logo
99 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
