Question about Dual XDVD8181 Car Video Player
Do not no the anti theft password
I do not no the anti theft password and my friend the original owner said that he had it professionally installed and he never put in a password so now im having a problem because of this anti theft lock code and the manual said that it is 0000 and that is not working also
  • Anonymous Aug 03, 2008
    DUAL XDVD8181 CAR VIDEO PLAYER
  • jtolin91 Jan 16, 2009
    forgot my password
I called the tech support line and they told me to push and hold the mute button and then hold the power button in at the same time for about 12 seconds. after that, a new screen should show up and the code is 122164. i have not been able to get this to work yet as every time i hold the power button in, it turns it off. even though i am holding in the mute button. i thought i would let you know this incase you can get it to work for yours.
Posted on Aug 05, 2008
Push and hold the mute button and then hold the power button in at the same time for about 12 seconds. after that, a new screen should show up and the code is 122164.This worked for me.Just make sure the power is already on when holding buttons
Posted on Dec 03, 2008
    Champion:
  • 227 Answers
Contact manufacturer and tell them the same, they will give you the master code. But they might make you send it in and charge a fee. Goodluck.
Posted on Mar 07, 2008
Ford S-Max 2007 PIN code required. I got VIN number: WF0SXXGBWS7S62481. Thank you for your respond.
Available in original owners manual for that VIN auto or from your friendly neighborhood stealer, I mean dealer.
On most car theft systems, the VIN is usually tied to the PIN code combination.
Nov 24, 2014 | 2007 Ford S-Max 2.0
Reset anti theft
If you do not have the password you are not getting in. It cannot tell if you have stolen it or not, so it will only proceed with the password that the owner will know.
Dec 20, 2013 | Samsung Cell Phones
My HTC windows 8s is stolen how to block?
contact your service provider to block.
for additional info. always install anti theft in your phone. (i would recommend avast antivirus with anti theft )
if you already installed any anti theft then goto website of AT and seek for commands. ( for that you must have registered your AT account and provided friends cell no.)
generally command for that would be LOCK *your anti theft password* and send this message from friends phone (one you already added to AT )
Jan 23, 2013 | HTC Windows Phone 8S
My car won't start, have had no problems it was running fine, pulled into the driveway shut it off, then an hour later it would not start. My anti theft light flashes excessively fast when I put the...
Absolutely! If the Passive Anti-Theft System (PATS) "thinks" you are trying to steal the car, it is SUPPOSED to keep it from starting. The problem is that the PATS thinks you are a car theif when you are not.
Below is a table straight out of the service manual for your vehicle. Please note that the FIRST action that must be taken for any PATS system malfunction is to scan the computer system for fault codes.
Aug 27, 2011 | 1997 Mercury Sable
My friend replaced the positive terminal cable on her 2005 nissan altima with a positive terminal cable from the factory and now the car won't start at all. There is power to all the fuses and the battery...
Hello.
It is very likely that the terminal is fine. Many vehicle owners are not aware that the newer factory installed anti-theft systems will lock down the car, ( prevent it from starting ), if the battery is disconnected for more than just a couple of minutes. In the future if you need to disconnect the battery, make sure that you dis-arm the anti-theft system first
You should be able to find out how to dis-arm/over-ride the anti-theft system in your owners manual.
I hope this helps you.
Donnie
Mar 07, 2011 | 2005 Nissan Altima
I have a 2000 pontiac bonneville SLE that had a secondary anti theft system put in by original owner. When battery was low it would kick in and disable car to start. I had car towed to a place and...
1st of all Read Your owners Manual, Depending on the Radio you have in it will depend on the Alarm system . Also Completely Disconnecting the Battery Will Reset your Security System
May 09, 2017 | 2000 Pontiac Bonneville
Reset anti-theft password
try simple code like 1234 this sould be the defualt
Apr 11, 2009 | Dual XDVD8181 Car Video Player
Keypad reset. Now that I have the original keypad code, how do I change the code?
your owner manual tells you. Why not use the original code?
To change, here is 96 procedure, should be the same. please give good rating if this is what you want.
Entry Code The system (permanent) entry code is located in three places:
  • on the owner's wallet code card (in glove compartment)
  • electronically accessible by requesting the remote anti-theft personality module KEYCODE PID on the New Generation Star (NGS) Tester
  • on the remote anti-theft personality module housing
The remote anti-theft personality module is programmed at the factory with a five-digit entry code. A replacement remote anti-theft personality module includes replacement labels and a new owner's code card. To turn on the interior lamps and light all illuminated components:
  • press any button on the keyless entry keypad (14A626).
To program a temporary access code:
  • Enter the permanent code on the keyless entry keypad.
  • Press button 1/2 within 5 seconds of last digit of permanent code. (This alerts system to accept temporary code.)
  • Enter alternate five-digit code. Do not exceed 5 seconds between entering digits or between pressing the 1/2 key and entering the first digit.
Apr 08, 2009 | 1995 Ford Taurus
Forgot anti-theft passwod
Default Anti-theft Password is "0000"
From the owner's manual:
In
the event you ever
loose or forget your
password, call our tech
hot line for support
on how to unlock your
system."
Dual Electronics Corp.
Toll Free: 1-866-382 -5476
www.dualav.com
Owner's manual at:
http://www.dualav.com/i/product/manual/xdvd8183.pdf
Feb 28, 2009 | Dual Electronics XDVD8183 Car DVD Player
Dual XDVD8181 Car Video Player Logo
451 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
