Question about Canon BubbleJet i560 InkJet Printer
Printer head porblem?
I checked printer head for foreing matter, but still get the error message (5 orange flashes).  Pls advise.
  • Anonymous Feb 17, 2008
    our canon wont print and also has 5 orange flashes , tried to turn off and restart to no avail . what do we do.
    Master:
  • 619 Answers
Hi , if you have printer reseter try to reset , if donot have try to visit canon web site to download reseter .
Posted on Feb 16, 2008
How can fix my error 5b00
Your video doesn't quite show how many flashes in the sequence.
six orange flashes means the CD tray door is down, seven orange flashes (the 5B00 error) can be addressed as below. Good Luck.
5B00/5B01 - Orange and green light blinking 7 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on.
Jan 06, 2015 | Canon PIXMA Office Equipment & Supplies
Canon printer i865 Orange light blinks 5 times and the following message appears: "Operator error. Press printer's RESUME button. If this doesn't clear the error, cancel printing and turn the...
Dear Bruce,
Blinking in orange 5 times indicates that the print head of your printer is faulty. To ensure this you can compare by using another print head. But first,please remove the print head and check whether it is burnt. Some short circuitry may cause the problem. Thanks.
Source:
Printer Clinic
Dec 26, 2010 | Canon Office Equipment & Supplies
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
    Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
    Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
    Cartridge error
    Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
    Sep 24, 2008 | HP Officejet 4355 All-In-One InkJet...
    Ip4000 5 flashing orange lights
    5 orange flashes indicates a problem with the print head. you could try carefully removing the print head (the thing holding the print cartridges) and replacing it. turning it off/on. make sure the print cartidges are ok. If still no good you might need to get it serviced?
    Aug 24, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
    Nothing will print
    5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
    Mar 10, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
    Canon BubbleJet i560 InkJet Printer Logo
    105 people viewed this question
    old marine
    old marine
