Sony Trinitron KV-29RS22 Blinks
Hi, I have a KV-29RS22 Sony Trinitron TV (Almost Flat, Black, 10 years old). At the beginning, when I turned it on, the picture started to blink on and off (no image) for about 3 or 5 minutes, after that image became stable, no problems with the sound ever. This behavior is the same in all video inputs.
I opened it up and cleaned it with air spray, removed all dust, but got worst, now tv blinks all the time but I discovered that reducing the picture from tv menu, the blink disappear. I tried to establish a point when the amount of picture does not causes the tv to blink again, but guess what, depending of what I'm watching it makes tv blinking, I mean, if I'm watching a movie where the background is kind of dark tv doesn't blink, if I watch a program or movie with some light on the background tv starts to blink, even if reduced the picture.
Some help will be eternally appreciated.
Thanks in advance.
George
  • GeorgeWaters Feb 11, 2008
    Thanks for your advice Sedonix, and I agree with you, I don't want to spend a large amount on this, I prefer to get a new one, but before I drop 800 dollars from my wallet, I'd like to see if this is a expensive repair. In the past it had the problem that sometimes the image disappear, it was a broken piece of weld, the repair cost 10 bucks, Do you think that this marginal high voltage involves spending a lot ?, Could it be just a cheap repair ?
    Thanks !!
  • Tatiana M Nov 09, 2008
    I have the same problem with my Sony TV. I bought it eight years ago for 2500 and can't afford to buy a new one. the audio is perfect but the picture blinks every few seconds
  • 579 Answers
Sounds like the high voltage is marginal.
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board by sending it to Module Exchange at 972-298-1212,
or PTS Electronics 800-844-7871 ptscorp.com.
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Posted on Feb 10, 2008
  • Greg Collins Feb 11, 2008
    A replacement flyback transformer will cost maybe $150 installed.
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Sony 32'' Trinitron that blinks off and on when turned on
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's wrong with it and how can i fix it?
Feb 07, 2010 | Sony Televison & Video
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Jul 14, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Tv repair
Undoutably the SMPSU (Switched Mode Power Supply) is faulty.. This will be a shop job... ensure you get a firm "Quote" and explanation B4 allowing it to be fixed.
Jul 26, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
