Question about Panasonic Lumix DMC-FZ7 Digital Camera
Dust specks on lens.
How can you remove dust from the lens inside.Does the camera have to be taken apart or is there a simple solution.
  • 3 more comments
  • blahblahblax Apr 24, 2008
    yes, I can't believe only 2 people have this problem. I take pretty good care of my camera gear too. Dust is actually under some type of thin front lens! What a stupid design!
  • Anonymous Jun 04, 2008
    My camera also has lots of dust bits INSIDE the lens. And I've only owned it for a year and a half!! Is there a way to get the dust out?
  • tyau Jul 08, 2008
    I have this problem, but no real solution other than to send it to a shop for repair. Most shops, though, cannot do this properly.
    May be better off finding a new camera. Honestly.
  • Anonymous Jul 09, 2008
    My FZ7 also has a layer of dust in the lens interior, the zoom is also a bit rough at times. Other than a slightly rough zooming and a dusty-looking lens, my camera is just fine. (I have had it for almost two years).
    Here's what I do to slow down dust from getting into the lens:
    I attached the plastic hood adapter that came included with the camera, then I screwed on a UV Haze-1 filter.
    Attaching a UV filter to a FZ7 not only slows down dust from getting inside, it also protects the lens from bumps and scratches.
    A UV filter can also prolong the imaging sensor's life.
  • Anonymous Jul 12, 2008
    No blahblahblax,
    THIS CAMERA'S DESIGN IS NOT STUPID!
    Other, if not most cameras have dust in their lenses.
3 Suggested Answers
SOURCE: How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
Posted on Sep 16, 2008
Obertelli
  • 3006 Answers
SOURCE: How can I take apart and clean inside lens? There
Sensor cleaning on your model is a job for professional technicians only and therefore not cheap. Dismantling your camera to get at the sensor requires specialist skills and knowledge and due to the small sensor size it must ideally be done in a sealed room with high levels of dust extraction if you want to avoid making the problem worse.
Any attempt at unauthorised disassembly will also invalidate any warranty you may still enjoy; even if the original warranty has expired there are sometimes camera faults which later arise that manufacturers have been known to retrospectively extend the warranty for so you potentially lose those rights as well.
A safer alternative is to use a supersonic vibration cleaner on the camera. These are sold to the public and to jewellers/opticians as a means of cleaning without chemicals and are usually filled with water, but you can find one with a large enough bed to sit your camera in and then it can be used dry. Your camera must be switched off when you try this, and must sit on it's base. The latter allows the dust to fall downwards and get trapped on the internal sticky dust trap built into your camera. If the camera is oriented any other way then you may dislodge trapped dust which may then fall onto the sensor. If you cannot find a suitable supersonic cleaning bath then you may even find that a ******** (yes, I DO mean the adult toy) set on it's fastest setting will achieve the same result. You need one that vibrates, not one that resembles an industrial jack-hammer...
Failing all that your only remaining option is to just accept that you're going to have to process out the artefact on every shot until it eventually falls off the sensor of it's own accord (no guarantee that it will though).
Good luck, and please take a moment to rate my reply.
Posted on Sep 14, 2010
Cleaning dust deep inside a 18-200mm vr
Unless you have a lens collimator and other gear needed to reassemble the lens, don't even think about taking it apart yourself. If gentle shaking and tapping doesn't dislodge it, take the lens to a reputable camera shop and have a trained professional clean it.
Jan 25, 2013 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Cleaning the lens from the inside
Cleaning the lens from the inside is not possible from a practical point of view. However, if you don't care that your camera won't work after you've taken it apart but you just want to see what's inside, then go ahead. If you see dust inside the lens and this is what is concerning you, please know that all lenses have dust inside...it can't be totally eliminated. In 99.999% of cases, the dust doesn't show up on the actual pictures.
Oct 17, 2011 | Casio EXILIM Card EX-S770 Digital Camera
How could I clean camera lens? The problem is I see a speck of dust in all my shots. Could I dismount the camera? Many thanks for your help.
the lens does not come off of that camcorder easily. if the dust is on the outside just use a little windex (spray the cloth, not the lense) and wife in a circular motion. If the dust spot (maybe its not dust). is on the inside you will have to have the lens taken off by a professional.
Mar 19, 2011 | Panasonic HDC-SD60 Flash Media, AVCHD...
I have several dust particles on the inside of the lens, betweeen the first and second glass elements of the lens. This causes dark "shadow spots" to appear on wider angle photos. How can I...
Hi there.
Sadly, point-and-shoot cameras are not designed to be disassembled and then reassembled easily. Therefore your best option is to take it to a store that specializes in camera repair.
Mar 01, 2011 | Panasonic Lumix DMC-FX7 Digital Camera
Lens error....shut down
try removing the battery and replacing it if this does not work you will definately need to take it in for maintenance
hope this helps
Robb
Nov 06, 2010 | Canon PowerShot A480 Digital Camera
Black spot on pictures - cleaned lenses and inside
The spots can be in the inside of the lens settings to the CCD/imager.
If the cleaning of the lens is done well it can be a speck of dust logged in to the screen and having it on the image.
A careful cleaning in a dust proof set up is required.
Sep 25, 2010 | Nikon D50 Digital Camera
Internal dust speck on Canon A720is in same upper right corner
If dust is in the camera, it must be opened. I suggest not doing this yourself. Lookup a Canon dealer in your region and ask for support.
Jul 22, 2009 | Canon PowerShot A720 IS Digital Camera
Dirt speck
It is probably a speck of dust on the sensor. Get a blower from any camera shop, remove the lens,lock up the mirror (mirror lock up in camera menu) and give the sensor a good blow ( without touching it) while holding the camera front down so that any specks of dust fall away from the sensor. Sometimes specks can stick (pollen for example) in which case you could try a disposable swab and cleaning solution, although if unsure most camera shops provide the service pretty cheap - the sensor would be a lot more expensive to replace if you mess it up.
Sep 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cleaning the inside lens
To access the inner optics on these compact digital cameras the lens must be disassembled from the inside out. Usually the camera casing has to be removed, boards and connections moved out of the way, and the lens assembly actually removed from the camera. At that point the lens can be taken apart and the inner optics accessed. In other words, yes, this is a job for a professional. It is also probably not worth the cost just for a couple specs of dust. These lenses are not sealed. This is why the dust gets in there to start with. If you get a can of compressed air and carefully blow into the gaps between the lens parts in different directions somtimes you can get enough air through to blow off the inner lenses. This does not often work though. David Millier Advance Camera Repair
Mar 12, 2007 | Sony Cyber-Shot DSC-P150 Digital Camera
550 Problem: Dust collecting inside Viewfinder
I had hoped that a few people would check their cameras and posted replies before I contacted Pentax about my dust problem, but nobody has so far. But it's interesting that someone else posted a message this morning that he has some dust inside the lens of his 550. Anyway, this morning Pentax Canada told me that there should definitely be NO dust inside the viewfinder or the rest of the camera for that matter. Although the Viewfinder is "almost sealed" from the rest of the camera, it is not a total seal - which means to me that if dust can get into the viewfinder, it can get into the rest of the camera's interior - including the lens and imaging chip. They have asked me to bring my camera in so they can remove any dust particles that are inside. Basically, they told me that the only place I should see any dust is inside the lens cover, which is meant only as a protective covering rather than a seal from dust. Even then, they claim that any dust on the outer lens would only enter while the camera is being used. That one I don't buy, as the lens cover is very flimsy and can easily be accidentally spread open while the camera is turned off.
Sep 08, 2005 | Pentax Optio 550 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
185 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
