Question about HP OfficeJet D135 All-In-One InkJet Printer
HP officejet D135 scanner and copyer
Get message scanner failure turn off power and try again ,scanner light come on scanner seem to be stuck ,have tried uninstalling and reinstalling software
still the same problem
  • learner2 Feb 24, 2008
    Same message - "Scanner failure, turn power off and then on again." Locks up all functions and makes it useless. Have attempted numerous suggestions for resolution since Nov. 2007 including HP Tech Support's "uninstall software" and reinstall d series software. Tried all 4 reset suggestions from RIZ but unsuccessful resloution.Repair service is $110 per hr. with a 1 hr. minimum and no guarantee the problem can be resolved. With the costs of near comparable new "all in one"" machines, I'm coming to the conclusion to junk & buy. Any suggestions.
  • Anonymous Jan 14, 2009
    #3 did not helped...
    After #6 the printer restarted without going into the light flash... The only thing is it is "initializing" for ever.
    Could not try the Full Reset as can not take the print cartridges out while the printer is under initializing or "flashing lights" (locked all the way to the right)
    Appreciate any suggestions …
    Guru:
  • 731 Answers
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Posted on Feb 11, 2008
Scanner failure
Scannerfejl. Kan ikke tilslutte til PC
Aug 05, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure
1. Check scanner light by trying to make a copy.
Caution: do not look directly in the light
3. Perform a power cycly
* Unplug the power cord from the product while its still on
* Plug the power cord back again after 30 seconds
4. Perform a semi-full reset
* Press and hold # and 6 while plugging the power cord
* Do not release the button unless the printer would say reset
5 If you still have the problem replace your printer
Aug 12, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner and coiper won't work printer does work
Hi Bbear,
The problem here is with the scanner bulb, the scanner bulb is bad.
I mean to say that your scanner bulb lit for a while and goes off.
This confirms that the scanner bulb is currupted.
I have a web link, which is given below with some of the troubleshooting steps to perform.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu01105&cc=us&lc=en&dlc=en&product=390315
Click on the web link given above and perform the steps.
If this fixes the issue, that would be great else you need to replace or get a new or refurbished printer.
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner won't work, printer and fax work
reinstall the print management software. May need to remove the printer, and re add under control panel. Got backup?
Hp officejet d135
Hi Paula.
Please click on the web link given below to get the issue fixed.
The problem is with the scanner bulb.
However perform the steps given in the web page below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=64986
Click on the web link given below to get the issue fixed.
Feb 04, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
376 people viewed this question
Ben Johnson
