Question about Navman F20 GPS Receiver
Navman F10 brought this unit for my daughter for Christmas. It switched on now it wont, we put it in the car to charge it and it still wont turn on. She hasn't even had a chance to use it yet.
I'm having the sam problem this is my secound unit what is wrong with things pls help
Posted on May 01, 2008
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Operating manual for navman f10,GPS
You can download the same from :-
http://safemanuals.com/user-guide-instructions-owner-manual/NAVMAN/F10-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 28, 2009 | Navman GPS
Navman F10 not starting
Apparently, according to the Navman helpdesk you have to open NavDesk and from the menu, go to Tools and then Recover Keys .
I tried this on my S80 and I got an error, (E000050) which I was then told I had to send the unit back for repairs. This is my worst purchase ever. I'm on my third unit and have had nothing but trouble.
Dec 06, 2008 | Navman Tracker 5500i GPS Receiver
Charging socket on navman pin 570 has come out
These sockets are on sale if you google enough. Ebay seller totalviews for example. Check its the right socket and be prepared for very small presise soldering. when you open the case, take great care not to break/dismantle the rocker switch that protrudes as it has minute elements in it. If charging is a problem but the socket appears sound,m check the plug that goes into it and ensure the springs go in and out to hold it in place.F4therchristmas
May 19, 2008 | Navman PiN 570 GPS Receiver
Navman icn520
check the battery switch on the back. you will need a pen. Mine does the same thing. I believe this switch has to be set to ON for it to work. At least mine wont turn on unless the switch is turned on.
Apr 10, 2008 | Navman iCN 520 GPS Receiver
Pin 570 wont boot after hard reset
RECENTLY I DID PRETTY MUCH THE SAME THING
SO HERE IS WHAT I DID :
" I TURNED IT ON AND HIT THE HARD RESET AND THEN LEFT IT ON TILL ALL P[OWER WENT AWAY FROM UNIT
SECOND I HAD TO DOWNLOAN A NEW VERSION FOR MY UNIT ; MEANING MAP
THEN I TOOK THE BATTERY OUT AND AND PLUGED IN MY USB CORD AND IT TOOK IT
I PUT MY BATTERY IN AND CHARGED OVER NIGHT AND WELL IT SEEMS LIKE A LOT TO DO BUT FROM WHAT I UNDERSTAND MY DRIVER GOT BOOTED OFF THE UNIT AND ANOTHER DRIVER FOR A MODEL WAS ATTACHED
HOW I DONT KNOW BUT MY UNIT WORKS NOW FOR THE LAST 4 MONTHS NO PROBLEMS
HOPE THIS HELPS YOU OUT RICHARD FROM CHICAGO
Mar 30, 2008 | Navman PiN 570 GPS Receiver
NAVMAN 570 PIN
maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Jan 23, 2008 | Navman PiN 570 GPS Receiver
Navman f10
Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should be working normally.this worked on mine.
Jan 12, 2008 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Logo
161 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
