Cant get my input instrument to come on
Evrthing is up n rnning fine, but i cant get my input intrmnts up in there.
Hi Toli
Can tell me the wch kind of instrmnt.Since,you have not mentioned...in ur mail..
Cheers
Arun.
Posted on Feb 14, 2008
My speedo, rev counter, fuel guage and temp guage have all stopped working on my 2002 focus 2.0 ltr ghia. All fuses are ok. Any ideas of what could be the problem ?
The instrument cluster is a hybrid electronic cluster (HEC) with two basic configurations, the base cluster and the optional instrument cluster. In addition to the two basic configurations, the SVT uses a modified optional cluster in combination with a separate oil pressure and oil temperature cluster. The base instrument cluster, optional instrument cluster and the oil pressure and oil temperature cluster receive and output information utilizing both hardwired circuitry and the standard corporate protocol (SCP) or the controller area network (CAN) communication network (2.3L only). It is very important to understand:
  • where the input originates from.
  • all the information necessary in order for a feature to operate.
  • which module(s) receive(s) the input or command message.
  • does the module which received the input control the output of the feature, or does it output a message over the SCP or CAN network to another module?
  • which module controls the output of the feature. Its more then likely you need a new instrument cluster.
Dec 19, 2014 | Cars & Trucks
Im trying to choose my inputs: (under preferences, Device) begin input1 and end input should be 8, but it only shows 2. Assuming I chose my ASIO4all driver that indownloaded. I can also chose Directsound...
The reason it does not work is because the PV8USB only sends the main mix to the USB. You need a different sort of beast altogether to do what you are wanting.
Apr 30, 2013 | Peavey PV8 Mixer
Lexicon alpha and gxl2200 microphone
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
Mar 05, 2013 | Lexicon Alpha Personal Recording Studio
How do i replace the input jack on my crate gx140c combo guitar amp?
Is this an integrated socket that is soldered to a circuit board or does it have wires going to it?
Mar 03, 2013 | Music
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
Hey i just got a boss br-864 and it was recording fine but now i cant seem to get rid of the distortion.Tried adjusting the input level and sensitivity but no luck.Would appreciate any ideas,thanks.
Troubleshoot. Try different cables, mics, instruments, etc to make sure that its the device and not something else.
Make sure you don't have any digital effects (compressors, guitar effect simulators, etc) activited.
See if there's a way to restore the device back to factory settings. Make sure you backup your recordings first.
Dec 31, 2010 | Boss Micro BR Digital Recorder
AIR IN DIESEL FUEL LINE
It be probably in the tank,check the pipe that goes inside the tank.
Nov 16, 2009 | The Times Case Corporation Tractors...
MY FREZEER IS MAKING EVRTHING FROST BIT.
Frost free freezer? If so check drain line to tray at bottom.
Nov 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ps3 guitar hero controller lights up two lights for controller numbers wont work any help?
From Activision's Support site:
The 2.80 firmware update causes the Guitar Hero instruments to connect to the Playstation with a high controller number. As a result Guitar Hero will not recognize the instrument at launch. To remedy this you will need to change the controller assignment in the Playstation 3 XMB system menu.
In the XMB go to Settings->Accessory Settings->Reassign Controllers. From here you will be able to change the controller number. Assign your first instrument to controller number 1 and increment the controller numbers for any additional instruments that you have connected. If you are using a microphone make sure to connect a standard PS3 controller before launching the game.
Jun 28, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
No output in Right channel on my Adcom preamp GTP-450
Hi...
Have you tried swapping speakers to see if the trouble moves to the other speaker?
It could be a dirty selector switch .
It could be a broken solder contact on the input or output RCA jacks
Feb 07, 2009 | Adcom GTP-760 Amplifier
Computers & Internet Logo
224 people viewed this question
Alun Cox
David Payne
David Payne
