Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Leaking from left wheel when applying trigger onmodel 7901
When we use the Bissell Pro Heat it leaks out of left wheel when applying the trigger. It sprays but also leaks out of left wheel. What is causing that???
    President:
  • 1,673 Answers
Sounds like a problem with the left spray nozzle, may be out of place. Either that or a line is loose and leaking. Either way you will have to pull the top housing off to check it over.
Posted on Feb 11, 2008
How to replace diverter valve model 7901 bissell pro heat steam
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
g,hk
Apr 04, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Brushes wont rotate
heatman101
uyk
Dec 24, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
No spray
You can to bissell.com and order them thru them, or they can tell you where the nearest place is for parts by putting in your zip code.
Feb 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel pro heat model 8910
Go to http://bissell.com/images/UserGuides/7901.pdf
This is in pdf format so you need adobe reader to get it, which is free on the net.
Aug 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
193 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
