Question about Audiofonics ADF-272 Car Speaker
HELLO is a 99 chevy blazer hey plz tell me sptep by step how to hook it up man plz the amp 801D is a old skool i dunno if it have a mono block fuction
    New Friend:
  • 101 Answers
IS THE OUTS ON RADIO TO AMP A SUB WOOFER OUTPUT OR A REAR OUTPUT? IF YOU CANT PLAY IN MONO (IT WOULD BE A SWITHCH ON AMP}.i WOULD RECOMEND GETTIN A EQ WITH A SUB OUT . I ALWAYS WENT WITH ALPINE.THEY MAKE A GOOD EQ,ITS A MUST FOR A GOOD SOUNDING SYSTEM
Posted on Feb 23, 2008
I have a 99 blazer 4x4 it is humming in he rear end we had the rear bearings n seals changed new diff cover new fluid and it is still humming what is it??? PLEASE HELP!!!
99 Blazer driving hum,noise - Blazer Forum - Chevy Blazer Forums
blazerforum.com > ... > Steering, Suspension & Drivetrain
Dec 31, 2007 - 99 Blazer 4x4 has constant noise-humming that occurs non-stop and increases and ... Sounds like it is coming from rearend but not 100% sure. 99 LT 4x4 Rear End Whine
Nov 5, 2013
7-5/8 or 8.5" ring gear?
Jan 16, 2012
99 Jimmy 4x4 humming noise
Dec 24, 2009
More results from blazerforum.com
Sep 30, 2015 | Cars & Trucks
Why does my 1998 chevy blazer have problems starting when the temp. falls below 20 degrees.
Could be a battery that isnt turning the starter the greatest. Try a bigger battery with higher cold cranking amps.
Jan 10, 2015 | OEM 1998 Chevy Blazer Radio / CD Player...
Hey i was wondering on the model punch 325.1 rockford amp what positive and negitive hook ups do i use for bridged channel.
the amp is a mono block so there is no bridge mode. The 2 speaker terminals are provided for easy connectivity of multiple speakers
Jun 05, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Stereo wont stay on and only couple speakers work
on the back of the stereo you should have an rca inputs in the back, it should say either rear, subwoofer, or non-fade. all of these are acceptable, run rca's to the amp from the deck.
also on the deck in the wire harness is a blue wire with a white stripe.
hook a wire up to this and run it to the REM. terminal of your amp. this wire tells the amp to turn on when you turn on your key.
these are the only two wires you hook up the back of the stereo.
hope this helps
Jan 07, 2010 | Sony Car Audio & Video
Why wont my 99 chevy blazer temperature warm up?
You may have vapour lock in your heater lines. Start engine, put heat lever on high, disconnect one of the lines on your heater core, the one on the flow out side, & see if you have any air coming out. Once antifreese comes out stick line back on & retighten clamp. Make sure your cooling system is topped off. Also your water pump may not be functionihg to it's maximum. Take rad cap off cold & view flow rate. If inadequate you may have to replace the water pump. Good luck!
Dec 09, 2009 | 1999 Chevrolet Blazer
Amp is a mtx 801d not sure
no you will not blow it out by hooking up both voice coils. But First before you do, what oms are they. and is your amp one oms stable? There a lot of ways you can wire double voice coil. But if you can get me that info i can send you some digrams to help you out and tell you whats best.
Oct 05, 2008 | MTX Thunder TA7801 Car Audio Amplifier
HELLO CAN SOME BODY TELL ME HOW TO HOOK UP MY SYSTEM RIGHT I HAVE 2 AUDIOFONICS ADF-272 1200 WATTS AND A MTX 4501 CLASS D MONO BLOCK AND A MTX 801D KIND OF OLD SCHOOL IS LIKE 4 YEARS OLD AND HOW TO series...
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
HERE IS HOW YOU HOOK UP 1 SPEAKER TO 1 CHANNELM DO THE SAM E TO THE OTHER CHANNEL. MAKE SURE AMP IS IN MONO MODE,YOU DONT WANT TO PLAY UR SUBS IN STEREO.AS FAR AS THE BOX DEPENDS ON VEHICLE AND HOW MUCN SPACE YOU HAVE .TELL WAT MODEL CAR AND ILL ET BACK TO YOU. I NEED A FIXYA RATING PLEASE
Feb 10, 2008 | Audiofonics ADF-272 Car Speaker
Audiofonics
i would go with the 801.And ithink u meant the 4501 not 4051.Both super power amps. competition stuff.your woofers are 4ohms dual voice coils.so you can series the coil on eaach woffer and use the two channels on the amp.they play at 2ohms.I think if you drop it down to 1 ohm you really be taxing you alternator that is series power.Yioou would need a special alternator.Even with them running in 2 ohms you better hav eat least a 2 farad cap.OR two batteries.. ! more thing don 't pump it up with window s closeed .you'll pop them.serious dbl. you be pumping.I'm jealous.Rating please and enjoy.
Feb 09, 2008 | Audiofonics ADF-272 Car Speaker
Help putting code in
hello i have 2 audiofinics adf-272 i dont know what kind of amp to hook up with it which one do u think is best for them a mtx 4051 500 watt class d mono block or a mtx 801d 800 watts
Jan 27, 2008 | Car Audio & Video
Audiofonics ADF-272 Car Speaker Logo
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
