Yes you can do this yourself with just some basic tools and a little patience and assistance.
You'll need to remove all food from the freezer as it will take at least 45 minutes or longer, depending on how well you do.
If you roll back the door gasket, you'll see the fasteners that hold the gasket in place. Remove these starting with the ones on the bottom edge and then the sides. Finally, remove the top ones, leaving the two top corners for last, that way you can have someone help hold the door liner, so it doesn't drop to the floor and get damaged.
I would also suggest that a day or so before you're going to do the repair, that you let the new gasket lay out on a floor somewhere where it can't get damaged so it will relax and get most of the kinks out of it from shipping, etc.
Then simply put the gasket onto the door liner and reinstall all the screws back onto the door frame.
You can find your gasket part at
www.searspartsdirect.com by entering in your model number for your unit and looking at the drawings and parts list provided.
Hope you've found this very helpful and best regards!
