Question about Refrigerators
Water drainage in fridge
I have ice all in the bottom of my freezer and now water is leaking out into my fridge. I have a Kenmore 70184001. The drain gets frozen up and I have to thaw it out about every 6 months. This is crazy to have to keep thawing it out like this all the time. Is there something else that I need to look at or do?
  • 25 Answers
You can add a drain tube heater to it to keep it from freezing up, part number is SH250 universal drain tube heater..
Posted on Feb 10, 2008
My kenmore side by side is leaking from the freezer door right at the hinge.. help. i just cleand the freezer not sure if i messed up the water lne that leads to the wter disnser.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Aug 26, 2014 | Kenmore Refrigerators
How do i unblock drainage hose in kenmore fridge?
Simply put must defrost the ice that built up after the food got stopped. This is a timely process and it will be messy so prepare yourself with some towels or a shop vac. pour the heated water over the drain hole wherever it is (depending on side/by/side, French door, bottom freezer, top freezer) but all have a evaporator coil where the ice builds up and just beneath it is where the drain will be located. Pour water there.
Aug 19, 2014 | Kenmore Refrigerators
Why is water leaking out the back and onto the floor of my Kenmore Elite Bottom Freezer Refrigerator?
Aug 16, 2014 | Kenmore Refrigerators
Every couple of days i wake up to a little pool of water that is leaking from my refrigerator. Any advise?
Jul 05, 2014 | Kenmore Refrigerators
Why is water leaking out of the freezer
Jul 04, 2014 | Kenmore Refrigerators
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Kenmore fridgerator is leaking water in the bottom 2001
the drain tube above &be hind ceiling has drain cup on older fridge this gets stopped up with gunk and stuff. held on back wall by 2 screws. This is a top freezer Your describing other wise the drain tube is in the freezer and you'd have ice in the floor of the fridge. If your fridge doesn't have it in the top back of the fridge compartment it is entirely in the upper freezer compartment and is still stopped up probably w ice and gunk. Defrost w hair dryer and while you can see the drain pan and hole pour in a cup of water if it goes down your good other wise blow out the drain with compressed air and retry the water. Please rate me accordingly and good luck.
Mar 13, 2009 | Refrigerators
There is water leaking from the bottom of the fridge
Hi!!! It seems that your drain line in the freezer section is plugged remove the bottom tray and check for ice or water if you do the unplugg your drain line with a hair dryer..good luck..
Jan 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
272 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
