Question about Sony DAV-SC5 System
The soud has no high frequences, how can i regulate them?
My sistem has poor high frequences, the basses and middles are good.
I don´t know how to change the frequence, is only by the "sound field" ?
There is another way, like the most of hi-fi systems?
Can you help?
Tanks!
There are no settings for this. I have the same problem, I think the speakers are tired. Ours gets used as a music system at parties so has suffered quite a bit of abuse. I have improved things a bit by swapping the front and rear speakers. The rear ones don't usually play as loud as the front, so were in better condition. Unplug the mains first, disconnect the wires at the speakers, move the speakers round, reconnect making sure that you keep + and - correct and give it a try.
Posted on Feb 21, 2008
My amp turns on good but after a while of too much bass causes a ugly sound too loud what could it be? Can it be repaired?
If you have over driven the amp by playing it real loud with the bass control turned up, it is very possible that you have toasted the output stages of amp.
Every time you boost a tone control by 3 db you have doubled the output power at that frequency. So if you are "coasting" along at a nominal 75 watts, the moment you boost the bass by 3 db the amp has to put out 150 watts at that low frequency.. Go to +6db and now the poor amp has to kick out 300 watts! And so on.
Rule of thumb - you never use your tone controls at very loud levels. Tone controls are there to compensate for the poor frequency response of the human ear at low volume levels - the Fletcher Munsen effect. At low volumes our hearing with the lows and high frequencies so when you play something at low volume you boost up the bass and treble to compensate for poor hearing. At loud volumes our ears respond properly.
Sep 12, 2015 | Car Audio & Video
Why is my speaker no playing, some sound but no bass?
Assuming that it is a large speaker with a large magnet on the back, and it has a large cone that was designed to play 'bass', if it has been dropped (or, for example was transported in a vehicle that went over a big bump - particularly with the speaker sitting perpendicular to the floor of the car/truck), the pole piece (magnet) in the very center shifts and pinches the coil between the outer magnet and the pole piece. This stops the coil from moving in and out through the magnetic field. Because high frequencies do not require much motion of the coil within the magnetic field, if the coil itself did not get broken in the process, higher frequencies (treble) will be reproduced (however poorly), but you'll get zero low frequencies (bass). This COULD be fixable, but a speaker repair specialist with a suitable demagnetizer would be needed to reposition the pole piece, and then, the whole cone would probably need to be replaced, as well. Depending upon whether it is an expensive (JBL/EV?) or a cheap speaker, it may be cheaper just to replace it.
May 10, 2014 | Audio Players & Recorders
Why is there four plugs on the back of speakers?
With four plug you will have a jumper from on plug to the other. (e.g. Positive to positive and negative to negative.) This is for single connection (two wires.) If you use two connections (four wires) you take out the jumpers. the bottom pair is normally for the bass and the top for treble. This is to make the speakers clearer, and sound better. As for louder,? I don't know some people think it does some don't. With better clarity of sound, you do get the feeling of it being louder.
Apr 27, 2012 | Audio Players & Recorders
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
I have a vsx-821-k reciever and cant adjust the bass
If the treble is good and is working then the failure to adjust or increase bass output even when it is done can be due to faulty OP-AMP in the BASS circuit. The BASS frequency must be enhance with an amplification and a pass filter with amplification boost and so a failure of this stage can be the reason for non action.You will need to have a signal test on the bass section to confirm the faulty IC.Check for poor solder joint and faulty capacitors/controls.
Dec 14, 2011 | Audio Players & Recorders
Very bad am radio reception, how do i fix?
If it's interference from the high tension wires,you probably need new spark plug wires with good resistor type plugs.
Now,also a bad antenna or a poor match of frequency to the antenna from the rec eiver can cause weak reception.Anyone who knows electronics can match the antenna to the receiver. don-ohio
Sep 14, 2011 | 2005 Dodge Magnum
Is the bass boost the gain or frequency knob?
Bass boost simply adds DB or gain to the bass signal. Some like it, some dont.
The frequency knob is the Low Pass Filter (LPF) that cuts off the amp output above
the set frequency. A bass system usually cuts off below 400 HZ and more often 200HZ.
A good, rattle your car bass note is in the 25-80HZ range or lower but most amps and audio
input devices cant attain a good low note with clarity.
"Low-pass filter allows only frequencies below the crossover point to be amplified. A high-pass filter allows only frequencies above the crossover point to be amplified - useful for keeping low bass away from small speakers, so they can play more efficiently."
Checkout Crutchfields Glossary of Car Amps.
http://www.crutchfield.com/S-LPyoWWgD5qN/learn/learningcenter/car/amplifiers_glossary.html
Mar 14, 2011 | Rockford Fosgate Car Audio & Video
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
I want to know what an User EQ is?
Most Audio devices will allow you to adjust how the music is played. an EQ is just something that can increase or decrease audio Frequencies. there are usually preset EQ levels that will make Jazz, Classical, Pop music sound better. this is done by increasing the High notes or increasing the low notes to give you more of a bass sound. User EQ settings allow you to manage the frequencies more to your liking. If you want to here the high notes better or adjust the middle to hear the vocals better then you can increase those levels. Or if you love your bass sounds then you would increase the lower frequencies to give your music more boom.
Jul 29, 2009 | Coby Audio Players & Recorders
Legacy Amp 2600 watt HELP
Hello e_cody_e,
The settings you have will not break anything and may sound OK.
But they may not be optimum for getting the best bass from your system. The SubSonic setting filters out frequencies below the threshold of hearing allowing the amp to put more power into the frequencies that can be heard. So, it should be set to about the same frequency that your enclosure is tuned for or just a little lower. If your enclosure is tuned for 35Hz, then the subsonic should be close to maximum.
Similarily, the low pass sends all frequencies below the setting to the subs, (other than those blocked by the subsonic filter) and is commonly referred to as the "crossover" frequency. Typical crossover frequencies for subwoofers are 60Hz, 80Hz and 100Hz. For a ported enclosure, lower is probably better.
The phase shift should be set to the position that best synchronizes the bass with the music. Because of the additional wiring required for the subs, the signal to them is sometimes slightly delayed causing the bass to be "out-of-sync" with the rest of the music. The thump of the bass comes just a little sooner or later than expected. If the bass sounds out of phase, turn the phase shift on, otherwise leave it off.
The "gain" or level control allows you to match the amps input to your head units subwoofer output. The best setting is usually as high as possible without distortion. Set it by turning up the head unit volume to about 3/4 maximum and then advance the amp gain until your subs just begin to distort. Then back it off slightly.
These settings should allow your amp to put the most power into the frequencies that your subwoofers are designed for and hence produce the loudest and lowest bass.
Hope this helps.
Jun 28, 2009 | Legacy Car Audio & Video
Sony DAV-SC5 System Logo
165 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
