Question about Yamaha RX-V3000 Receiver
Yamaha RX-V3000 Right Channel Crackling Sound
Recently, I began to experience a high pitch, crackling sound coming from my Polk RM 7500 right channel while watching a dvd, War, at high volume level. The crackling sound will come and go, very annoying. Obviously, something is wrong. The crackling sound appears at higher levels usually when listening in DTS, or any other high quality sound track.
When playing at regular sound track you kind of don't notice the sound distortion but if you get your ear close to the right speaker, channel, you hear a distortion in the sound from both mid and tweeter in that channel. I have check for wire connection and also use the speaker in the right channel to the left and vise versa and noticed that the speaker in the right sounded good in the left channel. However, the speaker that I moved from the right channel to the left sounded crackling, distorted on the right. To me is not the speaker but??? What could the problem be?
As I was typing this, I was listening at regular sound level without the high distorted, crackling sound and all of the sudden from the right channel distortion started at an annoying level.
I want to Thank You in advance for your prompt cooperation
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Distorted sound on all right channel inputs
yep but if your not a tech you should take this easy repair to a pro. Your problem is an open emitter resitor and happens when the units over driven or a speaker is bad for a while while it was working. if your a tech then check all of the emmitter resistors. also it could be a bad output device. Good Luck
Posted on May 28, 2006
smarthome2
  • 1114 Answers
SOURCE: I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Posted on Aug 13, 2009
BElectric
  • 1140 Answers
SOURCE: No sound from left channel
Hello Danza,
It's possible you've blown the left channel, but the fact that you have no audio in the left channel from both A and B speakers makes me wonder whether the balance control has been accidentally rotated to the right.
There is a rotary control on the front of the receiver for BALANCE. This should be in the 0 position, i.e. top dead centre. If it's been moved to the right, you wont get audio from the left channel from either A or B speakers.
Please check your balance control first then let me know if you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards.
BElectric
Posted on Apr 03, 2011
Sansui aux-410r amp crackling when switched on followed by high pitched sound and other sound like vinyl played at high volume and stylus being dragged across it .can anyone help please.
This is some kind of componant fault. To find out where determine if the sound is in one channel or both. If in both it could be in the power supply or in something that has both channels common to it. If in just one channel than at least you have the good channel to work with. You can test the bad channel by poking it with an insulated tool. It should make buzzing noises. If it makes buzzing noises in the good channel and is differerent in the bad in anyway you have found something. If the sound also comes and go suspect bad soldering.
Oct 27, 2014 | Audio Players & Recorders
I get static and crackling sound out of right speaker, then it blows the speaker fuse, Sanaui au-999 what is wrong
Any of the transistors in the right channel power amp section circuit will have the fault. Check it. A very skilled work indeed.
Apr 15, 2012 | Audio Players & Recorders
Sherwood Rx4050r and right speaker has crackling noises.
Ahh, that channel is blown. Its not 100% blown. This has happened to my freind before, and from my long knowlage in audio, the channel is blown, and is not fixable. If you REALLY are attached to it, you could probably bring it to a shop that fixes receivers, but best bet is to let it go
Oct 12, 2009 | Sherwood Audio Players & Recorders
Crackling / Popping sound in my PC's audio output
Your soundcard is going bad. The easiest way to fix is to replace with a new soundcard. Depending on what features you want the price could be anywhere from $35 to about $140. Hope this helps.
Aug 09, 2009 | Creative Labs Sound Blaster Audigy 2 ZS...
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
May 27, 2006 | Yamaha RX-V496 Receiver
Yamaha RX-V3000 Receiver Logo
261 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
