Question about Jensen VM9510 Car DVD Player
Jensen vm9311ts car tv
Want to install without having to have parking brake on . is there a code ,switch to install , or a box ?
Ground green pink wire
problem fixed
Posted on Feb 23, 2008
Difficulties in installin of VM9311TS
just by pass it with the bypass code
May 04, 2009 | Audiovox VM9311TS
Bypass brake code VM9311YTS
just connect the pink wire to the ground wire. some will tell you that a menu will pop up if so just input the numbers 5,4,3,2,1,0 make sure you hear a beep after every number. the menu will look like a hammer icon. im not sure if you have to input the code because i didnt need to
Apr 01, 2009 | Jensen VM9020TS Car DVD Player
Is a media link box and media module the same for jensen vm9311ts
they are not the same. the media link will work for that model.
Jan 17, 2009 | Jensen's VM9312 Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
BackGorund Change on a Jensen VM9311TS In-Dash DVD player
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Sep 24, 2008 | Car Audio & Video
Make is jensen vm9311TS
HI,
I'll let you know if the codes are available..
Jun 03, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
I doesn't work
the black box may be the very thing to protect your unit from harsh electrical environment such as coil back emf which can send much higher volts than 12 to the unit. it may be possible that the unit has been zapped and killed the video section. try installing in another car or even on the bench with a car battery.
Jun 04, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
283 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
