Question about Sony SLV-640HF VHS VCR
No picture or counter
First haft hour all is good then i lose picture and counter stops ,but tape is still runing.
  • 979 Answers
Are you sure the tape is still moving?...accordianman
Posted on Feb 15, 2008
I have an old Sony CCD TR55E Handycam, I bought from new. Now I want to transfer my tapes to DVD, and seem to have lost sound output playing tapes to TV/Recorder. Tried running tape cleaner, no succes
What is your signal path? The question you need to answer is, "Where are you losing the audio?" Are you losing it between the tape and the playback head, or are you losing it in the cable, or are you losing it at the TV/Recorder?
Does the camera have an audio out into which you can plug ear buds to test the audio from the camera playback?
Nov 28, 2014 | Sony Cameras
Tishoba vcr v-231 tape counter does not come on, no picture from vcr
Someone would have to look inside to see if the tape is not moving, no movement will cause it to shut down--have to look inside first.
Dec 10, 2012 | Televison & Video
I have a VHS tape that has an hour worth of recorded material on it, but when I play it, it plays the first 11 minutes, then it goes to static and the counter stops counting. I can fast forward but when I...
You may think the tape has an hour of material on it, but the machine thinks otherwise. Either it didn't actually get recorded past the 11 minute point, or something erased the tape past that point. There's nothing to play after that time, so you're seeing the snowy screen. On most VCRs, the tape counter only works when a valid video signal is detected, which is why it's not advancing as the tape plays. There's nothing you can do to recover whatever was on the tape, so I hope it wasn't anything important.
Aug 11, 2011 | TDK E-HG 120 VHS Tape
Intermittent loss of video (mimicking dirty heads symptoms)
Control head dirty. That is where the tape counter picks up the frame pulses.
Jan 18, 2018 | Sony SLV-N750 VHS/S-VHS playback VCR
Marantz CP430 fault
I have had the exact same problem with a CP430, Whether in Play Rewind or Fast Forward, after a short duration the tape stops. After a lot of Looking & thinking, I noticed that a few seconds prior to the tape stopping, the tape counter stops. (If you dismantle this unit be sure to work in an orgainsed fashion,& you will need some tiny Phillips head screwdrivers too) If your not confident then dont proceed.
The tape counter is driven by a belt, & on the spindle that drives the counter is a magnetic wheel, that runs past a sensor on a PCB.
I didn't have a replacement belt, so dismantled the unit, & chemically cleaned the Belt (cellulose thinners), until no more 'black' came off, in order to eliminate the possibility of tape slip, I also used a stiff toothbrush, to clean the plastic gears that drive the counter, as any resistance, will cause the belt to slip. I think the reset button had also been pushed hard, & bent the mechanism slightly, as it had a tight spot, so i adjusted the spindle, & finally lunricated the Counter gears (Not the Spindle & pulley, as its too close to the belt to introduce lubricant). Upon reassembly, The problem seems solved, the unit now plays records Rewinds etc, without any issues.
Its a tiny drive belt, & any resistance in the drive train, (dust / fluff / as tiny grit even) is enough to cause the belt to slip, & stop the counter which in turn stops the tape.
I hope this helps.
Thankyou
Apr 26, 2009 | Audio Players & Recorders
Losing picture while playing back 8 mm (analog) tapes
Hi there. Mine did the exact same thing for a few uses, then my playback screen went blue. You can see the menu, but the counter does not advance. I believe you are headed for the same situation.
Ask "Rifaa" for a solution. I read another post where "Rifaa" answered that the problem is a dirty tracking head, and there is a simple do-it-yourself solution to clean it.
Good Luck,
Sunny
Jul 08, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
No picture during playback
Only thing I can think is the tape may be blank. :) GOOD LUCK
Aug 18, 2006 | Canon ZR100 Mini DV Digital Camcorder
Toshiba MV13P2
since it fast forwards, and rewinds, my first guess (that the take-up mechanism is worn, which also causes the machine to "eat tapes" after it stops) not likely..... the other common problem is misaligned sensors (especially if you recently had a tape jam in it, or found a foreign object, like a pen, or piece of candy in it...... another possibility is that if it's with a particular tape, you may have visible gaps in the coating on the tape, which would trigger the sensors, basically saying "STOP.... END OF TAPE..." there are other sensors and sensing conditions that could cause the same problem....... have the mechanism and electronics looked at by an expert.......
Aug 01, 2006 | Toshiba MV13P2 13 in. TV/VCR Combo
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
