Question about Mitsubishi WS-65809 65" Rear Projection Television
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
1080HD Diamond Series 65inch rear projection 2001 Model
I am not getting a picture or audio from dvd player connected via component input #1 with audio input L & R via rca cables.
I am getting sound from the dvd play via the marantz surround sound system but no sound from TV speakers.
The last time it worked was right before I hooked up a Nintendo Wi to the inputs several weeks ago. I have checked to make sure the settings on the TV setup screen are correct.
The component 2 input video for the XBOX is not working either but the sound is working thru surround sound system but not TV speakers.
TV Inputs are as follows:
Ant-A Off
Ant-B On
DTV YPrPb(Charter Moxi DVR Box)
Component-1 On (DVD) Not working
Component-2 On (XBox 360) Not working
STB Off
VGA Off
Input-1 On (Cable) working
Input-2 On (VCR) working
  • 2 more comments
  • robertcaleb Jun 13, 2008
    I bought a Sharp Aquos Blue-Ray player and hooked it up to the component 1 but had no picture. I brought the dvd upconvert player i had in my son's room and plugged the same cables to the upconvert and the picture and sound came on. Unplugged the upconvert and tried switching the cables around but got nothing.
  • Anonymous Aug 05, 2008
    none of my component inputs work. I have 2 of them
  • jeffleimberg Jan 03, 2009
    not picture from DVD or Play station and tried to plug play station in front of tv at input 4. Sound but no picture. can't remember if problem started when HDcable box was worked on recently. Time warner disconnected my loop conection and antA connection?? Seems like input 4 would still work. Mitsibushi tech asked me to hook the DVD into the DTV input but still no picture. Hooked cable back up and picture.
  • jeffleimberg May 11, 2010
    What is HU'D on the cables. I have red to red, blue to blue and green to green
    Scholar:
  • 90 Answers
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
  • 67 Answers
Posted on Jan 07, 2009
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
HD52G887 no sound
Hmm.. If you have your television hooked up via component connection.. you may be forgetting the audio cable. This is a very easy mistake to make while component cables usually dont come with audio or optical audio cables.
Dec 19, 2008 | JVC HD-52G786 52" Rear Projection HDTV
No picture when cables connected
Go into menu on cable remote and open up 480p,480i,720 and 1080 . I think on some of those 1080HD only works on one of the two component inputs. The other is only rated for 720. Usually it has this info on set at input. Hope these suggestions are helpful.
Jun 09, 2008 | Samsung Televison & Video
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
RCA D52W15 52 in. Rear Projection HDTV-Ready Television
The component connections are usually video only and the audio goes to separate connectors set aside for that input. Check your manual to make sure you have all the connections made.
Dec 02, 2007 | RCA D52W19 52" Rear Projection Television
Mitsubishi WS-65809 65" Rear Projection Television Logo
1,047 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
