Question about Samsung SpinPoint P120S (SP2004C) 200 GB Hard Drive
Samsung sp2004c drive failure
Can not boot. Diagnostics indicate drive failure. The failing drive is a Sumsung SP2004C 200GB drive that is in a Compaq Presarui SR1936X desktop. When booting in safe mode, it goes as far as loading disk drivers and stops at
Any advice?
  • Anonymous Jul 05, 2008
    hd 521-2w error
  • 58 Answers
My guess is that your hard drive is corrupted. If you have any extra hard drives (external or internal), try replacing your current hard drive with that one, and see if that works. If it does, you may have to take your Hard Drive to a computer shop to have it recovered.
If that doesn't work, then something corrupted your operating system. I would re-install the operating system (reformat may not be necessary, but is always better than just a reinstall, although you do lose all of your information during a reformat), and then try.
Posted on Feb 11, 2008
I had one of these drives fail, and then the identical replacement drive provided under warranty by HP also failed after about 18 months. This appeared to be a failure to spin up due to bearing or motor issues. When repeatedly failing to boot, a message appeared requesting a valid boot drive. The bios could not see the hard drive at all, as if there were none installed. The drive made a nasty squealing noise for about a half second on each attempt to power up.
When we turned the computer case on it's side and removed the cover to check for loose cables and listen carefully to check the source of the bad noise, the machine booted normally. We were able to copy all personal data to an external drive. We had expected the data to be lost for good.
It is possible that by turning the case on its side the changed bearing orientation allowed the drive to spin again. the drive was mounted in the usual way in a tower case with the disks horizontal. Anyone with a dead hard drive could try rotating the computer 90 degrees as a way to get the drive going long enough to copy and move data.
Posted on Mar 28, 2009
I was able to get the drive back by using a "3 in 1 Cables Unlimited USB 2.0 to IDE & SATA Cable" ($34.99).
After strapping the drive into this device and plugging it into the usb of other computer, it auto ran the chkdsk utility upon booting, i.e. be sure to power up the laptop with the drive plugged into the usb. This fixed the problem - I transferred the drive back into my Presario and it now boots fine.
I appreciate your help. The one thing I failed to mention was that I had to get at the data on the drive. I couldn't simply reformat.
Thank you!
Posted on Feb 19, 2008
Half capacity
Please check it in here (probably there is an unallocated space):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management.
Feb 27, 2014 | Samsung SpinPoint P120S (SP2004C) 200 GB...
What does Error Code: HD521-2W mean and how to fix it
Nov 09, 2013 | Samsung SP2004C 200GB 7200RPM 3.5in 8MB...
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Dec 20, 2010 | Compaq Computers & Internet
Can not boot. diagnostics indicate drive failure. the failong drive is a samsung sp2004c hard dive in a compaq SR1920 NX desktop. Even in safe mode it goes as far as loading disk drivers and stops at multi...
You seem to have a boot up error. you can try using the derive as a second HDD on another PC & reformatting. if it fails, sorry to say your HDD is faulty, if you have warranty ask for a replacment
Mar 28, 2010 | Samsung SpinPoint P120S (SP2004C) 200 GB...
I need a sp2514n hard drive
this link will solve your problem..
plz give vote and ratings..
Feb 05, 2010 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
My sp2004c will not complete a CHKDSK with Win XP Pro. Is there a software to help me?
Chances are if it will not complete the chkdsk that it has hardware failures. If this is the case then no, software simply can't fix that. Time to replace the drive. If you have data on the drive, you will most likely need the help of a pro getting the files retrieved at this point.
If you need a pro, reply back with your Country, State and City and I will direct you to a nearby facility.
Aug 28, 2009 | Samsung SpinPoint P120S (SP2004C) 200 GB...
Getting write/read failure at 2F7EB56C
That is usually an indication of a Memory Address Failure. Most systems have 2 RAM modules, try the modules one at a time, see if the error goes away. If the error only occurs with one module, then replace that module.
If the error occurs with either RAM module, then it could also be a Hard Disk Drive error. If you can, run diagnostics from the F12 boot menu or the resource CD. If the Hard drive fails diagnostics, replace the drive.
Aug 07, 2009 | Dell Inspiron 2200 Notebook
Sp2004c sata hard drive is not recognised on system by bios or samsung hard disk manager all pluged in corectly to a new m/b, please help built a few pc`s now and not had this prob b4
  • Some SATA HDs have jumper for 1.5 G (SATA I) and 3 G (SATA II)mode. Try switching the jumper to 1.5 G or SATA mode (see motherboard manual).
  • Or you might need to upadte BIOS to support SATA drives.
Good Luck
May 11, 2008 | Computers & Internet
Computers & Internet Logo
1,640 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
