Question about Kenmore Elite 45986 Front Load Washer
Screw or change stuck inside tub
There's a loose screw or something thqt found its way through the stainless steel grating and it generates lots of irritating noise when the washer spins. How do I get in there to get it out?- Bo b
    Novelist:
    Champion:
  • 244 Answers
Only 3 ways to do this 1)take your sump hose off under the washer place your fingers on the inside of the washer and turn the drum slowly but watch your fingers the inner drum will act like a cheese grater i know this due to doing it myself and only once 2)got to strip it down totally but this is a big job m8 3)leave for a while it will find itself to the sump hose but this could damage your inner drum by tearing the side
Posted on Feb 10, 2008
Screw holding metal plate above element in upper oven to the roof has dropped out. The seating in the roof in which the replacement screw inserts has no fixing to take the replacement. Please help?
I came across the same problem on a friend's stove/oven.
It turned out that the threaded plate, like a wide nut, had come loose inside the top space above the oven cavity.
Found the exploded schematic on the web, then we rocked the stove to confirm something was sliding around.
Rather than dismantling the entire stove to retrieve it, I used a 6mm stainless steel pop-rivet to re-attach the element bracket.
Dec 19, 2017 | Ovens
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
Hole in stainless steel dishwasher tub... How can I patch it?
To make a permanent repair on stainless steel, it needs to be welded. If the hole is small & accessible from both sides, it can be repaired temporally by inserting a machine screw through a tight fitting metal washer, then a tight fitting washer; place the screw through the hole and install another rubber then metal washer on the opposite side. Tighten the washers in place using the proper fitting machine nut.
Oct 29, 2013 | Dishwashers
Loose handle on a Sub Zero 611 with stainless steel front. Used various allen keys but nothing is catching.
Unfortunatly there is no easy way to do this, but your on the right track. The handles are held in place by set screws, meaning there is not nut or bolt, the screw itself just pushes against the metal causing firmness. I found it easiest to get long allen head wrenches, lay on the floor with a flashlight, look up into the shaft and try to picture the position in you head and have at it. Persistance is the only way you'll win that battle.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Sub-Zero 695/O Side by Side Refrigerator
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
The bulb on top of my Melitta Java perk Model #MEP-10 Percolator is broken and I would like to purchase another if I can.
Go to the hardware store and buy a porcelain or stainless steel cabinet knob that will fit over the hole in the percolator top. Discard the screw that comes with the knob and replace it with a shorter (maybe 3/8") stainless steel version (shorter because the top of the percolator is a lot thinner than a cabinet). Then, buy a couple of neoprene washers and a stainless steel fender washer. Prepare the percolator top by using a hammer and a small piece of wood or something to flatten out the metal around where the old percolator top used to fit. Now you can start putting things together--slip the fender washer over the screw, then one of the neoprene washers and put it through the hole in the percolator top from the inside. Then slip the other neoprene washer over the protruding screw and screw the cabinet knob down, sandwiching the whole assembly nice and tight. Finally, tape a dollar to the old plastic percolator top and throw it away so you can say you've thrown away something.
Dec 07, 2009 | Coffee Makers & Espresso Machines
Replacing a baffle
this is a good one. easy too, once you see how its done, youll need to remove th top cover 3 screw across the top of unit, after removing the top look directly in the middle of the outer tub, youll see a black hose coming from the dispensor and entering diretcly into the top of tub. remove the hose from th tub( it will squeeze right out0. after that youll be able to see the stainless steel inner basket through the hole, youll have to spin the tub from the inside unitl the baffle is a t the top and oyu will see the screw hole will line right up,careful not to drop screw and remember to reinstall that hose or you get a flood
Mar 17, 2009 | Kenmore HE2 Plus Front Load Washer
Worn out front rim of plastic tub surrounding stainless basket
well not sure about yours but some front load washers have a five year warranty on the tub but you have to pay the labor which is between 100-150dollars
Dec 29, 2008 | Kenmore Elite 45986 Front Load Washer
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
Kenmore Elite 45986 Front Load Washer Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
