Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power button flashes 3 times but not turn on i here a sound in the back of the tv but tv will not come on was wondering if there are any easy checks or what might be a common problem for this and HOW DO I FIX THIS PROBLEM PLEASE HELP ME!!!!! thank you for your tome ANYONE / TECHMAN I have the same power up problem. In the past it would take a few tries but would come on. It slowly got worse and now it won't come on at all. Could it be the control board where the power on button is located.
  • 84 Answers
No, more than likely you have a bad power/deflection board. It must be replaced by a professional service technician.
C-Dog
Posted on Feb 10, 2008
Why won't it turn on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 14, 2015 | Toshiba REGZA 52RV530U LCD TV
Sound but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 03, 2014 | LG M2362D 23 in. LCD TV
No picture but has sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 06, 2014 | Sharp AQUOS LC60LE845U 60 inch 1080p 3D...
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA HDTV #D61W20, CHASSIS ITC222, Power button flashing 1, pause, 9. Possible error code 19, anyone know what this means
This is not a friendly chasis, the only easy fix that you might check on the power supply board and the left side (looking from the back) 3 capacitor (220,330,and 2200uf 16V) have the top pop up. Other than that poping, arcing noise, burn smell when first start up is bad york, Flyback Transformer and even the cooling leak for those tubes you will need professional TV repair man. Those TV picture not very nice anyway.
Nov 07, 2008 | RCA D61W20 61" Rear Projection Television
RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
phoenixx100@hotmail.com
http://www.angelfire.com/journal/archer/index.html
Oct 12, 2007 | Televison & Video
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
check the wires inside at the left lower region as you are looking at the rear. There are several circuit boards there that tend to loosen when moved. The cables are really ribbons like those used in computers.  I'd lioke to be more specific however I'm not entirely familiar with this model, just rear projection tvs in general.
Sep 05, 2007 | Philips 60PP9200D Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
