Question about Jensen VM9510 Car DVD Player
Vm9311ts jensen
Want to install without parking brake on ?
  • tdc3tdc3 Feb 10, 2008
    want to install without the parking brake on ,so can drive with it on . is there a code or a and on box or a switch ot make work with .
Wire to your ground
Posted on Feb 11, 2008
WHERE IS THE RESET BUTTON
isn't there a way to bypass the parking brake so my video plays anytime i want
can only see my video when i park and i bought for long trips so my girlfriend wont get bored
VM9311TS
Sep 18, 2010 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Difficulties in installin of VM9311TS
just by pass it with the bypass code
May 04, 2009 | Audiovox VM9311TS
Bypass brake code VM9311YTS
just connect the pink wire to the ground wire. some will tell you that a menu will pop up if so just input the numbers 5,4,3,2,1,0 make sure you hear a beep after every number. the menu will look like a hammer icon. im not sure if you have to input the code because i didnt need to
Apr 01, 2009 | Jensen VM9020TS Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
ITS just a ground cable hook it to the radio ground i did and mine works fine
Aug 21, 2008 | Jensen's VM9312 Car DVD Player
Jensen VM9311TS
plow boy442- I'm guessing you want your dvd to work while your driving. The unit has to be hooked to up to the e brake ,if you know which wire it is ground it out the unit will think your in park. Let me know , I can help you with this. cooltek Mar,3/08
Mar 04, 2008 | Jensen VM9510 Car DVD Player
Jensen vm9311ts car tv
ground green pink wire
problem fixed
Feb 10, 2008 | Jensen VM9510 Car DVD Player
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9510 Car DVD Player Logo
78 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
